JD 2305 Loader Leveling help
/ JD 2305 Loader Leveling help #1
BXinNH
Southern NH
Kubota BX24TLB
Hi,
A friend of mine has a new JD 2305 and his salesman did a poor job of explaining how to read/use his loader level indicator. I'm not familiar with how it looks or works either. If someone would post some brief instructions with pics that would be greatly appreciated.
Thank You,
Matt.
/ JD 2305 Loader Leveling help #2
Hi,
Thank You,
Matt.
I took the one off of my tractor (Not that same model though). Just tell him that the top of the bucket is on the same plane as the cutting edge, so by looking at the top you always now whats going on. By to answer your exact question, I believe you have top paint or otherwise make marks on the rod.
/ JD 2305 Loader Leveling help #3
On my 2305, a rod with a bend in it passes through an eye. When the bend in the rod is in the eye, your bucket is level. This of course, is only true if your bucket is on the ground, and your tractor is on level ground.
I agree with Kenny, and it doesn't take long to learn how much to curl the bucket when you are in float.
/ JD 2305 Loader Leveling help #4
my 3720 has an angled rod that goes through a loop. when the fixed loop meets the apex of the rod, the bucket is level.
/ JD 2305 Loader Leveling help #5
you can adjust the rod when you put a different attachments on also. I have to adjust the rod when I put on my pallet forks
Caterpillar D6H and D6H Series II Tractor Service Manuals (A63117)
Caterpillar D6H...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
Caterpillar 814/815/816F Landfill Compactor Service and Parts Manuals (A63117)
Caterpillar...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
Unverferth 330 (A64119)
Unverferth 330...
