Hole in muffler
/ Hole in muffler #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I was doing the usual checks this morning and noticed the black stain on the hood. Closer examination showed a small hole in the end cap weld of the muffler. It's not rusted through (nothing rusts out here in the desert). It looks like an incomplete weld or was intentionally left open.
I could understand a little hole in the bottom of the muffler to let condensation drain out, but why in the top?
It's an easy fix, but has anyone else seen this?
/ Hole in muffler #2
That hole looks to have been punched in with some sort of sharp object. I would just weld it up and put some high temp paint on it. I have never seen a hole left in a tractor muffler like that at least not on purpose.
/ Hole in muffler #3
Orezok,
I don't know how to break this to you ... but I think your tractor has been abducted by Aliens ... classic "probing".
Is it glowing? just asking?
hehehe
Tractor on
/ Hole in muffler
Orezok,
hehehe
Tractor on
I'm not surprised. I'm pretty sure my dog is an alien. At least she went to alien school before arriving here!
/ Hole in muffler #5
If you have welder hammer use pointed end to test both ends weld...yet to see anything as such.
/ Hole in muffler #6
Looks like the weld robot missed a spot.
10 seconds with a grinder, 5 seconds with a welder then some paint and it should be good to go. High temp flat black.
/ Hole in muffler
That's what it looked like to me also.
/ Hole in muffler
JB Weld can only withstand 500 degree temperatures long term. I have some muffler cement that would do the trick.
/ Hole in muffler #10
Could that be a bullet hole?
/ Hole in muffler #11
Is the hole on the under side of the muffler? If so, you should leave it open. Look at any modern automotive muffler, they have a hole like that one, to allow for moisture drainage. This helps the mufflers last longer.
2022 John Deere 5055E (A60462)
2022 John Deere...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2014 WINPOWER DR2014-AAMTJ GENERATOR (A59910)
2014 WINPOWER...
New Holland 354 Feed Grinder (A64047)
New Holland 354...
