finish mower oil from vent
/ finish mower oil from vent #1
tornadowatchranch
NE Kansas
Bobcat 335 for the fun stuff JD gt235 for the lawn
I recently got a great deal on a 7 year old 84 inch land pride finish mower. It was bought from a golf course so I figured it was well used. After filling gear oil to the proper level (bottom plug per the manual) shortly after running, it starts leaking from the vent hole. There is no noise or excessive heat (warm to touch after 20 minutes) after allowing time to drain back down it does not even show on dipstick. There is probably 8 ounces that came out of the vent. It spins quietly by hand when unhooked from the tractor. The first 3 people at the dealer had no idea of the problem. The last guy said that when the gears are worn it froths more inside of the gearbox and to either get a new box $$$$ or fill it with corn head grease. I leave it to the TBN brain trust to guide me here
1. any other ideas?
2. When a gearbox does give up does it seize (worried about damaging tractor here) or do they start clanking and making noise first?
I did a search and was not satisfied with how that related to my problem. One poster said not to worry as gearboxes vent until they reach the level they want???
/ finish mower oil from vent #2
Make sure the gearbox has a non foaming mineral based oil in it. We use a GL 90 in most of ours. Ken Sweet
/ finish mower oil from vent #3
I agree.. what oil are you filling it with? 80w90? or something thinner.
as long as there are no seals leaking, and the input shaft and the output shaft have no in/out/side-side play, and the shaft turns smoothly with no feeling of tooth skip on multiple revoloutions, then I would do the following.
drain oil in there and refill with an 85-140 oil like Mr sweet suggests.. ie.. non foaming, and I would also shoot in a few pumps.. or more than a few pumps of gun grease, then go mow with her. ( cornhead greas on top of the gear oil would be ok too )..
run her and keep check. the heavier oil / oil and grease slurry should still lube and cling to gears and slump to fill voids, but should be less likely to make it out of the brethar.
an oily residue at the breather is more or less normal.. but -loosing- oil is not. IE.. the oily residue might account for a tablespoon of oil per decade.. etc. maybee the same on a decent seal... ie.. you should not have to top off oil often. YEARLY at most.. and even that is a bit excessive IMHO...
soundguy
I was using a valvoline 80-90 gear oil that I had in the shop. I will double check for in-out slop. I didn't think of that only that it turned smoothly. I assume TSC or napa will have the heavier weight stuff.
thanks for the help
/ finish mower oil from vent #5
80w90 valv really shouldn't have foamed... that's a good quality oil.
you sure it wasn't very low? if real low it could have been slung and whipped easier.
85-140 can be generically bought in quart bottles everywhere.. napa, carquest, walmart.. etc.
carquest and walmart probably the cheapest.
85-140 and some shots of gun grease should help if there are no mechanical difficulties.
syphon old oil out with syphon gun or battery bulb / hand syphon pump... then add 85-140 to fill level, then add gun grease to fill hole.. give her quite a few good pumps.. nominal oil level is usually 40-50% up the side of the box.. even with the gear chunk in there.. there's plenty of room for some grease.. and you want it mixed and thickened and gooey.
do check for problems first though.. weepy seals.. loose bearings/shafts.. etc..
soundguy
/ finish mower oil from vent #6
shell rotela t walmart price 12.50 wts price 10.95 walmart is high on all oil they sell its called marketing and people seem to fall for it real well just cause there honey buns or cheaper dont mean anything else is they like the uneducated buyers
/ finish mower oil from vent #7
Check your vent plug. Some use a spring loaded check ball that hangs open.
Other times there doesn't seem to be a lot of thought given to the location, right above the gears where they sling oil on the fill/vent instead of off to the side.
The inside of the vent shows a screen covering the 3/8" hole. When I cleaned it and blew through it there was no resistance. The parts breakdown did not show parts inside the vent plug--just a single unit. Local dealer did not know. Maybe I will try to email land pride directly. They are actually build not too far from here.
/ finish mower oil from vent #9
if it is a pipe thread, you can always build a stand off.. get some pipe with the same thread.. a short section.. say 6".. get a pipe cap for it ( ie.. 4-6" of pipe threaded on both ends.. one end gets screwed into the box, the other sticks straight up with the cap on it. drill a small hole in the pipe right at the base of the cap.. smalles drill you have..
soundguy
soundguy
that is a great idea--it would allow the oil to run back into the gearbox. I will just take the vent into a hardware store and see what I can cobble together. I just ran it again without refilling the oil and it was foaming out within 10 seconds of getting up to speed. Will probably tip it up and completely drain and refill with all new oil first to try--who knows what they have been putting in it.
/ finish mower oil from vent #11
I vote for the corn head grease. If you have never used it, it is quite thin and works well in this type of gearbox. If the mower was from a golf course, I'm sure it has lots of hours but if it runs smooth I wouldn't worry about the hours.
/ finish mower oil from vent #12
yep.. could be anything.
if you are tipping to drain, then add in a lil diesel and spin the pto for a minute.. then drain.
that fitting is most likely pipe thread.. if so you are in business. many local hardware stores sell short threaded pipe sections.
if not.. heck.. make it from pvc.. a piece of 1" - 2" pipe 3-4" long, a cap, and then a reducer bushing down to 1/2" or whatever it is..and threaded end... doing it that way with the reducer you could even put a piece window screening wadded up inside the 'breather' to trap big debri and furthere help with oil moving out. then drill a tiny 1/8 MAX hole just under the farthest part the cap seats..so she can breathe.
that and the heavy gear oil and a couple squirts of gun grease and she's liekly done.
who knows.. she might have had jack oil or a palin hyd oil with no anti-foam properties in there..
soundguy
/ finish mower oil from vent #13
I have found the Valvoline 80-90 GL-5 synthetic oil does not seem to foam quite as much in gear boxes. The synthetic also seems to tolerate heat better.
/ finish mower oil from vent #14
All of the Caroni flail mowers seem to puke out oil from the breather cap. Basically it looks like the factory dipstick is just calibrated wrong so it encourages people to put in too much oil and the gears just fling it up against the breather cap once the oil warms up. It stops leaking when the dipstick shows minimally acceptable oil level. I wonder if too much oil could be part of the OP's problem.
I put in a two inch stand off on mine which works fine but I think just keeping a lower oil level would work just as well.
land pride answered back already and said that there is a spring or diaphragm in the vent. They said to either blow it out with air or order a new one. Will try that and post back after completed.
First of all thanks for the help.
Here is my solution for the benefit of the helpers and also the future "searchers"
First I tried to order the vent plug but a solid plug was shipped. I was not comfortable with that so I started with possible solutions:
1. built the stand off that soundguy and island tractor talked about--still foams out
2. drained the gear oil by picking it up with the FEL and refilled with 80w-90 valvoline--still foams out
3. added some seam foam thinking perhaps it was residual water--still foams out
4. drained again and refilled with chevron 85-140--still foams out
5. drained a few ounces and put in some lucas heavy duty oil stabilizer (that is some thick stuff) it foams up into the stand off but never came out. finally problem solved! I mowed for about 20 minutes and no problems. If it foams next summer in the heat will probably use some more lucas. I still don稚 know why it foams so badly but this seems to have solved the problem
Now it is time to clean off all the oil that has leaked and get some touch up paint.
Thanks again for the help
/ finish mower oil from vent #17
if it starts coming out again try 00 grease it is a gear oil but it thick and made for gear boxes
/ finish mower oil from vent #18
i wouldn't even wait.
I reccomended he put in some grease and do the stand off. whatever the geometry of that box and gears.. it must have the gears turning right on a air/oil boundry foaming it pretty darn good.
imho.. bad design..
soundguy
Just an update--8 years later and all is well. I have not touched the gearbox as far as a fix since my last post. I mow probably 30 hours a year with it. All is well in Oz.
/ finish mower oil from vent #20
good to hear.
