Lincoln Spool Gun
/ Lincoln Spool Gun #1
DIXIEDOG
Maine
International 2544 / Gator 825i/L2501/General
Here's a little info for those on the fence about buying the spool gun for their little Lincoln wire feed welders. It's not an expensive gun, it was around $200 which is downright cheap for a spool gun....that is reflected in little things like not having remote wire speed control so you still need to go back to the welder to adjust it, you also can't use 10 lb spools with it, you're stuck with the 4" spools only.
I purchased the Lincoln spool gun that fits my Lincoln 140C 110 volt welder early in the summer and have used it on several projects with excellent results. Set up was quick and easy and after running a few beads getting the hang of it was easy as well. It was well worth the investment and it does a far better job than a 110V welder should be able to on aluminum. :thumbsup: As a disclaimer this is not a production gun so if you intend to go into business welding aluminum you should look elsewhere but for the homeowner who would like to do some aluminum welding for small projects it's a great deal. The reason I post this is I have read alot of posts on several forums about the smaller welders lack of ability to weld aluminum and how they would not have the power to get good spray transfer.......it was nearly enough to put me off. Luckily for me I talked to a guy on another forum who had actually hands on used one of them and he eased my concerns about it's abilities. I'm glad I tried it.
/ Lincoln Spool Gun #2
Thanks for the info, I have the Lincoln 180C 240V and have thought about welding aluminum for light projects and for bicycles or where you want a chrome look for a cheaper price but just hadn't looked into it much because of the initial price to get set up. That gun price doesn't look to bad though.
/ Lincoln Spool Gun #3
I have a 180 pro-mig 240v and bought the gun to weld some 1/4 aluminium and it worked flawlessly . I would highly recommend this gun for small volume aluminium welding.
/ Lincoln Spool Gun #4
I'm new to welding. I actually have never welded anything as of yet. I just purchased a lincoln pro-mig 180 welder. Can someone tell me what the spool gun is needed for? Thanks
/ Lincoln Spool Gun #5
A spoolgun is generally used to weld aluminum as the wire is too soft to be fed from the MIG welder itself. It will usually birdnest (bunch up between the rollers and the entrypoint into the liner of the gun). A spoolgun puts the wire right at the gun (welding point), rather than 15-25' away.
Hope that makes sense.
/ Lincoln Spool Gun #6
Thanks, great explanation. I see one in my very near future.
/ Lincoln Spool Gun #7
Thanks for the info guys. I love my 180T, may have to broaden its horizon.
DRL
/ Lincoln Spool Gun #8
I recently bought a spool gun for my Lincoln Power mig 255 at about $1200.00. I only got a couple of hours to play with it before I had to pay attention to other things and messed up the first job badly. You've now given me hope that I've not wasted the money. I expect to find the time to try it again this winter. THANKS
/ Lincoln Spool Gun
I'm not sure how much experience you have with wire feed welding but here's a tip if you haven't, wire speed is used to adjust amperage....you may need fiddle with it a bit but once you get the settings down it will work excellent. At $1200 you must have a very nice production spool gun, you will be able to achieve great welds with that combo.
/ Lincoln Spool Gun #10
wire speed is used to adjust amperage....you may need fiddle with it a bit but once you get the settings down it will work excellent. .
Can you explain this a little more in depth to us novices ?
Can I also throw this out there I distinctly remember in college a I spelled "aluminum" for a test in statics & strength of materials class and the Proffesor said it was wrong it should be spelled "aluminium" , but one of my spell checkers says it is wrong the other says its right this is making me nuts. Thanks for letting me rant.
/ Lincoln Spool Gun #11
Ok, I'll give the amperage a shot. Basically it is working on the prinicple of resistance. The longer the wire is from the end (stick out) creates more resistance is between the tip and the work. It doesn't seem like it should be that drastic but a welding currents it's enough. So the longer the stick out the lower the amperage delivered to the weld pool. Of course you have to balance this with the distance from the work and that your gas mix will have to be adjusted. In most cases with the smaller welders you want your wire to stick out from the tip about 1/4 to 1/2 in.
I hope this is accurate and if not then I hope someone can explain it better.
/ Lincoln Spool Gun #12
I wish there was a $200 spool gun option for the 255. For $1200 I just don't weld enough Aluminum. I have had luck with just making sure the cable has no tight bends to it and I set the wire feed delay long enough after welding so the wire doesn't stick to the tip.
/ Lincoln Spool Gun #13
I'm nearing retirement and have always wanted one so I bought it while it's still tax deductible as I used it for work. Gotta love it when the government subsidizes about 45% of the costs. Yes, we pay that much tax here.
/ Lincoln Spool Gun
The easiest way to understand the wire speed / amperage correlation is
The welder is trying to maintain a certain length of stickout, as you increase wire speed you welder needs to use more power to maintain that length of wire stick out so it increases amperage to maintain that length.
Voltage settings on your welder also play a role as you need enough power available to run a given wire speed but that's an easy way to think of it. The wire speed is what you will use to make minor adjustments to your amperage. More wire speed = more amps
Also when you weld the aluminum make sure you are using a push motion rather than trying to pull the weld.
/ Lincoln Spool Gun #15
Just write AL :laughing::laughing::laughing:
/ Lincoln Spool Gun #16
The easiest way to understand the wire speed / amperage correlation is....
..... More wire speed = more amps.
We're going to get kind of confusing here just as soon as folks realize that more wire speed = more amps.....
Except when it doesn't, as when BPW says "So the longer the stick out the lower the amperage delivered to the weld pool."
Personally I find that there's enough interrelated things going on that it turns out to be as easy to do as to explain. It does help to have someone looking over your shoulder when learning, and I've found that most people can learn to turn out decent welds in an afternoon. Most of it comes simply by watching the pool of molten metal and developing a sense for keeping that pool clean and moving right along.
rScotty
/ Lincoln Spool Gun #17
So what your saying is if I have a 3/8" stickout at a given voltage with a wire feed of 220 and I increase the wire feed to 240 this increases the amps to overcome the increased stickout I now have but isn't all I have done is decrease the arc current , because I thought shorter is hotter and longer is cooler when it comes to electrode stickout .:confused2:
/ Lincoln Spool Gun
Yes :thumbsup: It's somewhat confusing but that is the jist of it.
If I have confused folks with my description I apologize, that was not my intent.
/ Lincoln Spool Gun #19
They make and aluminum kit for the 255. It consists of a teflon liner, plastic guides and cut back tips. I use mine for replacing aluminum floors in dump trailers. Also dont use 4043 wire use 5356. It is stiffer and feeds easier.
Bill
/ Lincoln Spool Gun #20
Bill
Years ago I use to install commercial aluminum store fronts. One of the company we bought stock from also sold almost every size and thickness and it was about 1/4 the price of what I could get it locally. Now that's not really an option so I really don't weld much Aluminum anymore. The last thing I did was weld a new skag on the bottom of an outboard maybe 5 years ago. I just like tools and spool guns look cool.
2019 PETERBILT 567 (A67714)
2019 PETERBILT 567...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A67714)
2016 PETERBILT 567...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
Unused 2020 Kodiak 4AP Towable Aerator Tractor Attachment (A66734)
Unused 2020 Kodiak...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2006 FORD F-450 SUPER DUTY SERVICE BED (A67714)
2006 FORD F-450...
