Getting ready for winter.
/ Getting ready for winter. #1
Topkicker
Eolia, MO
Kubota L2501
The dealership picked up the Massey this past Wednesday to add an engine block heater and a 84in rear blade. Got a color match canopy also. Will post some pics when I get it back to the house. Bring on the snow!:thumbsup:
/ Getting ready for winter. #2
Sweet lets see it!
/ Getting ready for winter. #3
Give us some prices if you don't mind.... especially in the block heater.
/ Getting ready for winter. #4
Always good to be the early bird when dealing w/old man winter..don't forget to stock up on coffee. ;)
/ Getting ready for winter. #5
I put my block heater in last year for my 1652. It cost $90.00 from Northwood Power Equipment.
I asked for the engine block heater and the first scheduled service for free to seal the deal. He threw them both in. It's been a pleasure dealing with Harmony Outdoors here in Indiana.
/ Getting ready for winter. #7
The MF block heater cost me $150. But the really good deal for you is the 50 hr service included in your purchase. That's worth over $500, based on other posts lamenting the high cost of shop labor.
/ Getting ready for winter. #8
Mine starts fine, without a block heater.
However, I do keep a silicone pad heater attached to the bottom of the transaxle, plugged in.
/ Getting ready for winter. #9
Scott, I got one for my 2310 a couple years back... it was pricey and I don't use it real often, but the install went very well --it fit beautifully-- and it sure is nice to have it when it's really cold!
Here's a tip- during the summer when it's not used, you can remove the electric feed from the heater and cover the opening with a standard garden hose cap- same size and thread. That helps to keep the electric cord/plug from getting damaged and keeps the heater connections clean. (I'm assuming your block htr is the same, of course.) Just be sure to remember where you put the electric cord...:laughing:
  • Block htr w:cap.JPG
    Block htr w:cap.JPG
/ Getting ready for winter. #10
Great tip-I'll be doing this in the spring.
/ Getting ready for winter. #11
Where can we get these?
/ Getting ready for winter. #12
I got mine for J.C Whitney. They don't seem to sell them anymore.
I have been watching this seller on E Bay they have a bigger selection, including all kids of engine heaters, at good prices: Engine oil heater oil pan heater 120v 100watt NEW - eBay (item 180459020000 end time Sep-30-10 11:46:06 PDT)
I think mine was 140 watts. If you want, you could go bigger. They have a 250 watt model the same dimensions as the 100, and 150 watt.
I worry about the hydo pump a lot more than the engine.
When you see the warm up times in the manual, you can see they want that oil warmed before you start working it.
About half of us are also running synthetic trans oil in hopes that it will also help with this problem.
When the heater has been on for a couple days, the bottom half of the axle is warm to the touch. So I know the oil is much warmer than without it.
Newbies keep in mind that a diesel engine runs cool at an idle in cold weather, so after a couple minutes you want to set the throttle up to a high idle, for proper warm up.
/ Getting ready for winter. #13
irvingj, thanks for the tip about removing the MF engine block heater cord. Mine has been dangling all summer, and I wondered if there was a better way.
I've used my heater a few times already, and it seems to warm up that area nicely, and fast. Veteran tractor guys, please share your thoughts on how much engine idle time is needed if you've already warmed it up with a block heater. I see the comment about turning up the RPMs from idle before moving out. Does that still apply if the engine has been warmed with a heater?
/ Getting ready for winter. #14
Yes, because you still have the 5 gallons of hydraulic oil in the trans that needs to warm up.
/ Getting ready for winter. #15
I use the block heater to make starting easier, certainly easier on the battery. Since I haven't yet switched to synthetic transmission oil, I still allow several minutes for the whole tractor to warm up before working it.
Depends on the temp- at around 15-20 degrees, 9 or ten minutes; longer when it's colder. I also always start out gently when beginning it to work it.
So far, no broken things!:thumbsup:
I got the Massey back yesterday. Love the new blade. It even has a stand to keep the three point off the ground for an easier hook up. It's 29 degrees here tonight so I left the Massey outside with the new block heater plugged in . I want to see how well it starts in the cold. Here's the pics of the blade and block heater.
/ Getting ready for winter. #17
Hey to all,
I hope you can use this information on the block heater for the GC's, :D.
http://www.tractorbynet.com/forums/...-gc2410-coldest-weather-starting-problem.html
Most of the information about it is on post #29 & post #43.
It is getting that time to install my front blade, then when the ground is frozen, I switch to the snow blower. Already has been down to 16 degrees F and one of the shallow lakes 5 miles away is already half frozen over, :cool:.
KC :thumbsup: :thumbsup: :thumbsup:
I went out this morning to start the tractor after leaving it outside with the new block heater plugged in. It was in the mid 20's and there was frost on the hood and even the seat. All I can say is wow! It started as soon as I turned the key with no puff of black smoke. It idled smoothy right when the engine fired. I think I'm going to leave it plugged up even when it's in the garage. I can get started out of the garage quicker and no more smelly cold start that fills up the other bays.:)
/ Getting ready for winter. #19
I also installed a block heater on my VW TDI-- it starts just fine regardless of the temp, it seems (perhaps a bit rough for half a minute or so), but-- it's sure nice to have heat right off! I live on top of a rather large hill, and it's downhill almost all the way into town; not much heat gets generated by that little diesel on the way to work in the AM!
The other reason I like to use it, and I didn't realize this til later, is that it starts right up with no black smoke, as Topkicker noted. That's nice, as I keep it in a garage. A lot less sooty residue on walls & ceiling, I expect!:thumbsup: Just one more reason to justify a block heater.:laughing:
I done some research on snow removal on concrete drives and decided to mount skid shoes to the scrape blade. The last thing I want to do is catch a joint in the concrete drive and break it. I was playing with the adjustments on the shoes today along with the top link and got the blade as close to the drive as I could. I think it will work great. All I need now is some snow.:D
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
3096 (A63117)
3096 (A63117)
