Mag drill?
/ Mag drill? #1
1grnlwn
Central Illinois
bobcat 773
I have ordered a Jancy mag drill, it is on the small side due to a < $1000 budget. I just wanted to have the capability to drill accurate larger size holes. It has a 1 3/8" dia capacity and is single speed 450 rpm. Any advice on mag drills?
/ Mag drill? #2
I have a under 1,000 mag drill don't recall the brand. love it buy the carbide
bits will last longer than high speed ones. 1/2 inch is as small bits you can buy
but you can buy standard drill quill works well. Use cutting fluid.I Have drilled
several hundred 7/8 holes in 3/8 steel. You will like alot for holes over 1/2 inch.
/ Mag drill? #3
Does your Mag drill have a chuck or use annular cutter bits. They come in 1" or 2" length. I have a Milwaukee Mag Drill and while it is great, I don't use it as much as I thought I would. :mad:
/ Mag drill? #4
If you use the drill in a position where it can move or fall if the power is shut off then tie it off so it can't fall or swing out and smack you on the side of the head.
/ Mag drill? #6
Isn't that going to be a little fast for large bits ?
Yes, but not for these! ;)
/ Mag drill? #7
When I was out hunting for a Mag drill I wanted one with variable speed and be able to put a chuck on it when I wasn't using annular cutters. I found one that fit the bill. That being said you have to make sure your power cord is in good shape and not able to be unplugged especially if your stuck on the side of some structure. I use a lockable cord and attach a tether cord to the drill just in case I lose the power for some reason.
My main use was when I was out mobile welding. I would take it along with me. I also don't find them much good if your trying to use the magnet on thin metal such as 1/4". The thicker the plate the better. Mine gets very little use. I had to look around here to find it it's been that long since I used it :eek: good luck with your new drill. I'm sure you'll really enjoy it from the first time you use it.
/ Mag drill? #9
I see. Didn't realize mag drills commonly used annular bits.
Any reason why ?
I don't know if I'd say annular cutters are common, in an industrial setting yes, for the home owner no!
They drill faster, (cut less material) and last a lot longer. Down side is they're very expensive!
/ Mag drill? #10
Also curious as to how these annular cutters handle higher RPM when standard drill bits start smoking.
Wonder if I could convert my press to run annular, it's a tapered pin chuck drive.
/ Mag drill? #11
I never seen them run with many RPMs so I can't help there.
I use them all the time on my mill. I took a 3/4 R-8 adapter cut about 1/4 off the end, ground down one of the catch lips on the annular cutters, they work great! :thumbsup:
/ Mag drill? #12
They do fine at 450RPM because they only cut out a ring (annulus), and
therefore much less metal, versus a same-size twist bit.
Anyway, I converted my drill press to run the annular cutters and run at
180RPM. See here:
http://www.tractorbynet.com/forums/build-yourself/169219-annular-cutters-better-way-drill.html
For those who have invested in the mag drills, maybe you would use
the annular cutters more if you could use them on thinner steel in your
press or mill?
If you are a pro and need to drill big holes in steel fairly often, you might
consider cobalt or carbide annular cutters. HSS is fine for me. I bought
a set of 6 Evolution cutters for $100.
/ Mag drill? #13
I have a Milwaukee mag drill and only use it for drilling large holes on flat surfaces. I have never figured a good way to line it up when trying to drill something like a frame rail. It is just to heavy to hold in position line up the hole and then turn on the magnet.
Bill
/ Mag drill? #14
Bill
Our Jancy, Hole Hawg, and Milwaukee magnetic drills are all adjusted to the center punch the same way, they are gently? tapped into place with a ball peen hammer or what have you, we mag them higher than the hole center and let gravity take over while adjusting them, works going up also while vertical pos. Yes you will mar the magnet with hammer marks, our tool mechanic says he never has to touch the magnetic area during repairs from such use. Hope this helps, mag drills sure can take the load off a person's wrists.
/ Mag drill? #15
We have a mag drill at work that has an X-Y adjustment. Just get it close w the magnet and then dial it in exactly. Milwaukee, I think? Pretty large unit!
/ Mag drill? #16
An X-Y adjustment would be a very good option. I guess a hammer
works as a form of brutal X-Y adjustment.
Anyway, on frame rails I imagine that the thin steel will keep the
magnet from holding on very well (HOOKED).
/ Mag drill? #17
..................thin steel will keep the
magnet from holding on very well.............
That's correct. I borrowed the one fr work to drill my bucket a few years back and while it would hold it's own weight, it would not hold against the pressure of drilling.
/ Mag drill? #18
And your bkt was 3/16 to 1/4 inch thick, most likely. Sometimes you
can put a thick piece of steel behind the area you are drilling, but that
won't work for tubing or non-planar surfaces.
I first used a magdrill back in the mid 70s at a lab where I worked. I
do not remember having any annular cutters back then, however.
/ Mag drill? #19
Bill
My Milwaukee is adjustable after it is stuck to the work. There is a toggle lever that can be backed off so the drill head can be moved around. My old Black & Decker has to be tapped around.
As far as the magnet pulling up when drilling I think I read in the book where the base material has to be 1/2" thick for full magnetic force. I have never tried a backing plate under thinner material. I have stuck the drill to a chunk of 1/2" plate and clamped the plate to thin material to use the Steel Hawg cutters.
If you are using it in any other position than flat be sure to add a safety chain in case the power fails. No power = no magnet = it's going to fall
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64556)
2021 Mercedes-Benz...
2018 John Deere 6155M (A64911)
2018 John Deere...
