skid-kid
Member
Well I know there has been a lot of snowblower talk going on with winter fast approaching. I bought a 59 for my 3320 about two weeks ago from a dealer about two and a half hours from me. He said it was a 08 that was removed from a 3320 that the owner just had to have his loader on so he brought it back, didn't even wear the paint out of the shute. He assured me everything was there to mount and operate it on my 3320. When I picked it up I knew the front hitch was not the correct one that I have seen for a 3x20 and again he assured me it was. I looked this hitch up on JD parts and the only model I could find it under was the 4000 series. The water was starting to boil. However when I went out to see if it would work out it did, no modifications. I did have to remove the brush guard for clearance to lift. I also had to remove the lift arms for my 72D MMM. It was fairly simple and I can switch back and forth from blower to loader. It doesn't take any longer to hook up than anything else on this tractor. I will have to remove that hitch to go back to the MMM in the spring but all the more wrenching it took to do the swap was easily worth it. I attached a few pics so you can see it, they were from my phone so I hope you can see them. Like I said the only place I could find the hitch that came with it was for the 4000 series. Maybe it was for the 3X20 also I don't know but it worked. The driveshafts came with it also. I just thought this might be some good information for 3x20 owners to know if you come across a used one with a different hitch. I know someone will correct me if I'm wrong.
