1920 Muffler Extension Solution
   / 1920 Muffler Extension Solution #1
wood butcher
NW Arkansas
Kubota 3130
I have been hunting for a muffler extension for my 1920 NH. (It's the part that goes up vertically from the muffler and bends to complete the stack) Anyway. I went to the NH dealer & they wanted $65.00 for it. I decided to try the regular muffler shop today to see what they'd charge to make one. $10 is what he charged me. He flared the end so it would fit my new muffler and bent & cut the top end of it. Cant beat that price!!!!!!!!! Just thought I'd share that with you guys needing a new exhaust extension.
   / 1920 Muffler Extension Solution #2
I allways shop around when I need a tractor part. Some times you can get the part you need somewhere other than a dealer. Save $$$ is what it is all about thewse days.
   / 1920 Muffler Extension Solution #3
Cool, I took a piece of EMT (Electrical Metallic Tubing) out of a scrap pile, cut, bent the tip and bevel cut it. It's been holding pretty good in the last 5 years. Cost me 15 minutes of labor.
JC,
JC,
Nice Work!!!! I just couldn't make myself spend $65 on a piece of metal worth $3.00.
I allways shop around when I need a tractor part. Some times you can get the part you need somewhere other than a dealer. Save $$$ is what it is all about these days.
I agree. Before the economy tanked I had a great paying job and could (foolishly) afford over-priced things like that but these days I have to watch every penny.
   / 1920 Muffler Extension Solution #6
on my 1920 I removed the short bent piece and added a piece off the shelf from autozone. already had the flair and I just used a muffler clamp on it. was a couple foot tall straight pipe that I added a flap cap to. think that cost me 10$ 10ys ago too.
when i sold the tractor i asked the buyer if they wanted the oem bent short stack or the taller one with the flapper cap.. they wanted the flapper cap..
I 'think' I still have my oem bent short stack in the barn somewhere..
that reminds me.. they wanted the non oem bumber i made out of angle iron and expanded metal... looked real good.. did it with mig and a chop saw and a torch..
soundguy
soundguy
NICE WORK SOUNDGUY! I was originally going to knock the rust off the old stack with a wire wheel & paint it with high-temp paint but after taking a close look at it the metal was so thin I didn't think it would hold very long. Glad I went to the muffler shop!
   / 1920 Muffler Extension Solution #8
yep, the oem stack is like 3 times thicker than aluminum foil.. so yeah.. the muffler extension you used is going to be a WHOLE lot better.
soundguy
   / 1920 Muffler Extension Solution #9
That's odd, 'cause the one on my 2120 has pushed many a branch out of the way for me and never bent. Maybe it's different from the 1920 unit. I did have to reweld the bottom of the muffler, as the whole thing had bent back from hitting things, but the pipe held.
Jim
Put my new muffler & $10 stack on last night. Everything fit perfect!. I thought those 4 rusty bolts were going to be a bear but I sprayed some WD40 on them, waited a few min & they came right out.
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
3 PT DIRT SCOOP (A51243)
3 PT DIRT SCOOP...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2015 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Kubota RTV500 (A47384)
