BX2200 compared to the BX2660
/ BX2200 compared to the BX2660 #1
jetblue4400
Kubota Bx2200
I have a BX2200 with the loader ,60 inch deck and snow blade BX 2763 since new in 2001 with 418 hrs and it has been a wonderful little tractor and never been in the shop for repair.I'am considering looking at a new BX 2660 with the front loader ,and deck but I'am not sure if it would be much of a upgrade from the 2200. I mow 2 acres and some of that is mowing a long hill and use the loader lightly.The 2200 does hold the hill very nice and never seems unstable and I would need the same feeling from a new one. Any thoughts?
/ BX2200 compared to the BX2660 #2
In 2008, I sold my BX2200 thinking I "needed" a B2920 (long story). I decided the BX was the right tractor and began looking at them. I chose the BX2660 over the BX2360 primarily for the seat and have not regretted it a minute.
I can lift a little more with my FEL and the 2660 has noticeably more power than the 2200. The 2660 is every bit as stable as the 2200 which is great and one of the reasons I did not get the B2920.
A real big advantage for me is the ease with which I can swap out the FEL. On the BX2200, you have to loop the hose back into the tractor and you have to be all the way into the FEL arms before hooking up. I would usually put my FEL on/off twice a year. On the BX2660, it is a three minute job and I have taken the FEL off and on twice in a day's time.
YouTube - Removing a loader from the Kubota BX24
The BX2200 is a great little tractor and my old one is still going strong, I visit it every two weeks, but the BX2660 is definitely worth the money, to me at least.
/ BX2200 compared to the BX2660 #3
I had a 2000 BX 2200, and used it for 9 years. I can't imagine the 2660 as being much of an upgrade. I wanted/needed a B, or else would still have my BX.
Will
/ BX2200 compared to the BX2660 #4
I did what your thinking about doing and if I had it to do over I'd keep the BX2200 and the cash. I thnk my 2200 had almost as much power at least when plowing snow. Maybe the 2660 is a little better running stuff off the PTO.
/ BX2200 compared to the BX2660 #5
I would not consider it an upgrade. What appears to be an edge in horsepower is not a real edge in power. The engine in the BX2660 has been tweaked such that it will run at a higher RPM and thus on paper, produce a higher peak hp. Once you put a load on it, it will lug down to a lower RPM and pretty much have a similar torque output to the BX2200.
There are a lot of discussions in the archives, by people who understand it a lot better than I, regarding hp vs torque, and how all the factors of bore size, stroke length, bore/stroke ratios, total displacement, compression, etc. play into all the equations. You could do some searches and find a lot of information if you are so inclined.
/ BX2200 compared to the BX2660 #6
Per the Kubota specs page the 2660 has a larger displacement engine (1001cc vs 898 for the 2360). Does the 2200 have the same displacement as the 2360?
If the specific output is nearly equal between the two, then the displacement ratio would suggest that the 2660 would make the 25.5hp that Kubota say's relative to the 2360's 23hp (1001/898) X 23 = 25.6 With no need for additional rpm. Does that make sense?
/ BX2200 compared to the BX2660 #7
Had them both plus a BX1500 and BX2350. Very little difference ibetween the BX2200, BX2350 and BX2660. Except for abrupt stop in reverse in the BX2350 and better seat in the BX2660. Now have a BX25 which seems to run smoother, quieter and rev quicker than the BX2660.
If you just want to trade, then trade but I don't think you'll be able to convince yourself that you've made much of a change.
I went from the BX2200 to a B7800 which was a noticeable difference.
/ BX2200 compared to the BX2660 #8
The BX2660 does have more power and is larger displacement. Realistically, I think the only way to benefit from the extra power is on the PTO.
With that said...I had a BX2230 and sold that to a friend with low hours and looked like new and purchased a new BX2350- Sight unseen as it was the next generation kubota and had delivered to the house. I was mortified in the quality of the plastic parts and fit-up, and the extremely loud hydrostat noise. Immediately called dealer and rep allowed for dealer to take back. Now I was stuck. Had to wait a couple of months for the next model BX that had Metal parts and a redesigned hydrostat-Quieter. That ended up being a BX2660. Cost extra from the BX2360 but that came our almost a year later.
Summary: I wished that I had kept my original tractor! I new the use and maintenance history.It did everything that I needed and still do now. I was just chasing after something that looked newer, possibly smoother with a couple of newer features that ending up not really making much of a difference. Should of saved allot of money and just went to the dealer and bought a couple of hats with my next round of maintenance supplies instead.
Don't get me wrong, I love me BX2660. But they are designed to last a good many years and I will be getting my value out of this one. I seriously doubt that I will be getting rid of this one any time soon. I don't even care if Kubota, down the line comes out with the NEW Super Improved Subcompact Model BX3090 30HP deluxe version with heated seats, floorboard & steering wheel, tires that cannot go flat, underbody lighting, liquor dispenser, Ice cooler and a snack tray.......
/ BX2200 compared to the BX2660 #9
It's funny how different perceptions are. We immediately noticed the power difference between the 2200 and 2660 in pushing brush and trees and while digging with the FEL.
I don't have the time to use the BX much any more and my wife refers to it as "her" tractor, but we have both said overall that we would do it all over again even though the 2200 is a really good tractor. Like I said in my previous post, it is not just about the power, but the improved loader controls, 1.4 inching valve, easier engaging PTO, seat, low profile front tires, much improved instrumentation etc.
/ BX2200 compared to the BX2660 #10
Yes there were some good inprovements. and even more over the BX2200 compared to my BX2230. and your post is refreshing my memory. Yes I can also tell some differences on power on other applications as you suggest. I love my BX2660. But with all said, given the oppertunity to do it over I would still have my older tractor. Than again the BX2200 is quite a few years old by now and maybe the OP feels that he has gotten his value out of it as you did and it will be his turn to support Kubota and stimulate our economy.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
159119 (A60430)
159119 (A60430)
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
