Kubota's dipstick
/ Kubota's dipstick #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
OK...How do you measure the oil on your Kubota? With the dipstick forced/screwed all the way down, or with the rubber part at the top of the stick just resting on top of the dipstick hole? I can't find that answer anywhere in my operator or shop manual, but it must matter because the difference in the two positions is larger than the difference between the "add" and "full" mark on the stick itself. Maybe Kubota is just shy about discussing their dipstick?
rScotty
/ Kubota's dipstick #3
mine is just like a car, push dipstick all the way in.
/ Kubota's dipstick #4
As long as it is showing fluid, I am good.
Always maintain the high level ... these machines are designed to have X amount of quarts of oil in them.
/ Kubota's dipstick #5
I always do it all the way in. Its the way I was taught. Just like a screw on type, o rings or screw, do it all the way. Like the other poster, I keep it topped off as well.
/ Kubota's dipstick #6
Not to derail the thread but the L3400 manual says 7.5 quarts with a filter change. I put exactly 7.5 quarts in, and the oil level is quite a bit above the top hole on the dipstick. There was no old oil left in it after the change...I left both drain bolts out for probably 30 minutes and drained the block completely.
So my issue is, the manual says 7.5Q for a oil + filter change, but the dipstick is saying it's got too much in it. And that's with the dipstick shoved all the way in while the engine is cold. Am I running it too full of oil or do I ignore the dipstick and go with the manual? My thought is that maybe the extra showing on the dipstick while the engine is cold is what will fill the oil filter when the engine is running....but on everything else I've ever used, the top hole is full when the engine is cold....
/ Kubota's dipstick #7
All engines have pockets or valleys that hold oil when you are changing the oil out. You rarely get everything out that would allow you to just put in the exact amount specified. That's why most oil changes look a little dirty 1hr after being changed. Tractors seem to be more prone to hold oil.
Over filling means the crank is more likely to contact the oil and cause excessive splashing and aeration. Not good.
Go by the dipstick. Change filter/oil, run for 5 minutes, shut it off, wait 5 minutes, check dipstick and add as required.
If you over fill, drain some off by removing the filter and drain it and reinstall or temporarily removing the drain plug and let a little out. Recheck the dipstick after running for 5 minutes and shutting it off.
Then make a note of how much you did use, and the next time you should be right on the mark.
/ Kubota's dipstick #8
rScotty
edit: Hgh tech ted- if the engine is cold and you did not fill the oil filter simply let it idle to attain its safe oil level-no worries.
If the oil an inch above the high oil mark when hot you need to drain a pint-no worries as the crank case vent relief tube is doing its job.
The dip stick has to be fully inserted and secured as the crankcase is vented and will have no vacuum release when the dip stick is pulled which would affect the oil level due to the change in crankcase pressure.
The whole thing still makes me wish they used the double basin dual dip sticks for the high/low sumps to this day rather than use one common sump.
If the oil filter is vertical you can fill it with oil to be sure it adds to the total volume with no worries about overfilling anyway.
/ Kubota's dipstick #9
My L3400 manual calls (purchased new in 2008) for 6 quarts. I had the 50 hour service done at the dealer and noticed that it was above the high mark on the dipstick. I figured it was okay since the dealer performed the service, but after working the tractor shortly after the service, I noticed a bit of carbon build up on the loader. I cleaned the loader off and drained the oil to the high mark on the dipstick when the dip stick is fully inserted. Much less carbon build-up. The manual says black exhaust is result of too much oil. When I change the oil, I put in less than 6 quarts. I think I put in 5 1/2 maybe? When the tractor was delivered new its oil was in the middle of the dipstick range.
/ Kubota's dipstick #10
My manual shows the information for both the L2800 and the L3400. The L2800 says 6.0 Quarts, the L3400 says 7.5Q (both with a filter change).
I'll check it at idle and see what it shows. I'm not really worried about it, just drain a little and move on...
/ Kubota's dipstick #11
I have a F2680E. It's sitting in the garage and hasn't been ran in a few weeks. I'd bet money that if I pull the oil dipstick now it will show oil just on the tip of the dipstick. When I wipe it off and reinsert dipstick and pull it out to check it the reading will be at the full mark.
This has always baffeled me since on cars/trucks the oil will reach the highest level after sitting for awhile.
The vent relief valve Leonz mentioned must have something to do with this on the F model Kubota.
/ Kubota's dipstick
Will you check it with the dipstick pushed all the way in or not? I'm still curious which way Kubota says to measure the level. So far, nobody seems to know for sure....but we all do it one way or the other...
rScotty
/ Kubota's dipstick #13
I wish I had a dipstick for the hydro. instead of that little round window :laughing:
/ Kubota's dipstick #14
Leonz said,
The dip stick has to be fully inserted ...
Do you not understand english?
/ Kubota's dipstick #15
I understand English well enough. Things I do not understand so well are fools, insults, and arrogance.
rScotty
Now ain't that the truth ...
/ Kubota's dipstick #16
Hot dog .... :laughing: Now we got a party :D
/ Kubota's dipstick #17
If this unit is a diesel and this is the case; the crankcase breather tube may be partially plugged and needs to be inspected.
Mice and the yellow jacket/ paper wasps are always an issue with diesel equipment that has been idled-parked during warm weather.
I hope no one thinks I was being insensitive or insulting them. The new units may or may not have a rubber o-ring to secure the dipstick to keep it in place.
/ Kubota's dipstick #18
Mice and the yellow jacket/ paper wasps are always an issue with dielsel equipment that has been idled-parked during warm weather.
I hope no one thinks i was being insensitive or insulting them. the new units may or may not have a rubber o-ring to secure the dipstick to keep it in place.
Where is this crankcase breather tube?
/ Kubota's dipstick #19
Hello John,
if it is like the Duetz air cooled diesels it is in the front of the engine near the flywheel.
Some of the Kubotas have a crank case breathyer tube coming off the side of the crancase too.
You will notice a slight black oil film around the base of the crankcase breather tube when you find it.
If you have the mower off and the belly exposed you will see it if you are sliding under the engine with a creeper or on a tarp as it is a round pipe with an open end.
/ Kubota's dipstick #20
Hello John,
Thanks Leonz. The mowing deck is out front and not around the motor so should be easier to find.
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
1996 Chevrolet Astro Cargo Van (A64194)
1996 Chevrolet...
JCB 3TS-8T Compact Wheel Loader Skid Steer (A64553)
JCB 3TS-8T Compact...
2007 Toyota Tundra 4x4 Ext. Cab Pickup Truck (A64556)
2007 Toyota Tundra...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2011 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65053)
2011 GENIE Z-45/25...
