winter prep
/ winter prep #1
henrysMFGC2310TBL
Carleton Place, ON
JD D140
I will be storing my 2310 outside under the lean-to and would like advice on what you do to winterize the tractor. I will be checking the anti freeze strength and putting something in the fuel(what do you use). Any other advice? Thanks.
/ winter prep #2
Some guys go to a lighter weight oil...I don't, but I'm quite a bit south of you.
Main thing I'd do is add a block heater. My tractor is kept in a garage most of the time, but having had a diesel pickup...even if the glow plugs or intake heater does the job, it's so much easier on the engine with a block heater.
Trickle charger on the battery might be advisable too.
As far as the fuel, I use Power Service or Sea Foam. Make sure you run the engine a bit to get the winterized fuel throughout the fuel system.
/ winter prep #3
Also I would recommend to fill the tank completely to eliminate the possibility of condensation in the tank.;)
/ winter prep #4
That won't hurt. But, with the tank being plastic, your not really going to get condensation.
An often over looked item is the owners manual recommends changing the antifreeze yearly.
I no longer do that. But I do use fleet antifreeze for diesel engines, and add diesel additive annually until it tests good.
Hardi Navigator Pull-Type Sprayer (A66285)
Hardi Navigator...
Landhonor 2-Ton Hand Chain Lever Hoist (A66408)
Landhonor 2-Ton...
2016 CATERPILLAR 311FL RR EXCAVATOR (A65053)
2016 CATERPILLAR...
Gehl Mix-All 95 Grinder-Mixer (A66408)
Gehl Mix-All 95...
Kiefer Built Livestock Trailer (A66285)
Kiefer Built...
2013 Buick Verano Sedan (A64557)
2013 Buick Verano...
