Black bucket or JD green?
/ Black bucket or JD green? #21
The 70 loader has a green bucket, and when they started calling it the 70A loader, the bucket was more squarish and painted black. I think a lot of 790's had the 70/70A loader on them.
Partially wrong!! The bucket on my model 70 loader was and is factory black!
/ Black bucket or JD green? #22
My 1993 755 has a 70A loader with the black bucket.
You have me curious about your loader. The manuals and JD Parts all show the 70A is not for the 755. It is possible the wrong decals could be on yours. JD in their own advertising doesn't always pull everything together correctly. The attachment shows what is clearly a 70A (on an 855) with 70 decals. Are your masts vertical, or kinked? The s/n plate on my 70 loader (with black bucket) includes 70A in the sequence, but does not mean it is a 70A. The s/n plate on my tractor shows 755D, but of course that only indicates 4WD and SCV, not a model change designation. Again just curious about this mostly trivia, although it could become important if ordering parts.
/ Black bucket or JD green? #23
More trivia:
Note on square, round, green, black, or anything else buckets. JD Parts still shows exactly the same information as my 1992 parts catalog. Meaning only three part numbers for buckets: 48, 54, and 60 inch. The drawing shows the rounded style, and no designation is given as to color. One number of course matches my black square bucket. I expect alll the combinations met JD specs and you just got what JD got from its vendors. In the industry that's called meeting form, fit, and function.
/ Black bucket or JD green? #24
Welcome,, my 790 also has the 70 loader with a black bucket.. If you paint it green it would have to be shiney like the tractor and would be a pain in the butt to maintain, flat black (read this as cheap paint) is the best.
Regards
N2deep
/ Black bucket or JD green? #25
I had a 790 with a 70 loader and a 54" bucket. The factory bucket was flat black. :thumbsup:
/ Black bucket or JD green? #26
You have me curious about your loader. The manuals and JD Parts all show the 70A is not for the 755. It is possible the wrong decals could be on yours. JD in their own advertising doesn't always pull everything together correctly. The attachment shows what is clearly a 70A (on an 855# with 70 decals. Are your masts vertical, or kinked? The s/n plate on my 70 loader #with black bucket) includes 70A in the sequence, but does not mean it is a 70A. The s/n plate on my tractor shows 755D, but of course that only indicates 4WD and SCV, not a model change designation. Again just curious about this mostly trivia, although it could become important if ordering parts.
Picture worth ten thousand words, it is a 70 loader. Sorry.
/ Black bucket or JD green? #27
That's OK. Always enjoy pictures of other 755's anyway. I thought maybe you had one of those rare factory errors. My custom ordered Ford Explorer is a Limited model, but when it came in it had an Eddie Bauer model emblem on the back. Probably was the last thing to go on the vehicle as it came off the assembly line. Everything else was correct so I had to point it out to the dealer so he would change it. Of course I had immediately spotted it.
/ Black bucket or JD green? #28
The change to the black squarish bucket did about line up with the introduction of the 70A loader,but I wouldn't say that was the reason. Originally two versions of the 70 loader were sold. One to fit the 755 and one to fit the 855. Same loader, the 855 version just had a longer horizontal frame to fit the tractor. Later the 855 version was changed to instead "kink" the masts forward. They called that the 70A, while the 755 (and 770) retained the 70. Since buckets were sold separately from the loader, some 70A got black and some got green.
Thanks for pointing that out, I had assumed incorrectly that the round/squarish bucket came about because of the 70/70A change....but that shows you what assuming will do!
Is my loader an oddball then.....70 loader with kinked masts?
/ Black bucket or JD green? #29
Thanks for the picture. It's entirely possible as they made the transition to the new style masts that they produced some with the 70 decals. The early ad in my previous post was the same way. Always more for me to learn, and still more trivia for the historians to figure out. Is your loader serial number above or below 110001?
/ Black bucket or JD green? #31
Serial no. is 111xxx
Did some more research on the s/n break for parts differences. It had to do with how the metal hydraulic lines attach to the boom, and some difference with the loader support. Early booms used bent over welded tabs to hold the lines while later ones used a clip and nut. I can't tell what the difference is with the supports, but since the serial break applied to 60, 70, and 70A loaders it doesn't seem like that is the key to the kink difference.
In looking at my old printed parts catalog, I see the difference in serial numbers between 70 and 70A. Other than the first year 1988, 70 loaders for the 855 had 70B in the s/n while 70A loaders had 70AX . However, the surprise here is all the overlapping years of 70 and 70A production. So obviously there is much more to this than I thought. Maybe I should just step aside from all this trivia, but I am curious what letters are in your s/n. 70B or 70AX ?
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
