Check your motor mounts
/ Check your motor mounts #1
IslandTractor
Super Star Member
Prudence Island, RI
2007 Kioti DK40se HST, Woods BH
While greasing today I noted a missing motor mount bolt. I checked the other three on that side and all were loose. The other side was all right.
Mine is a DK40se with just over 200 hrs but I'd imagine this is an issue for all tractors. I routinely check BH subframe mounts with each oil change but had not checked motor mounts before. I will now.
/ Check your motor mounts #2
IT-
Thanks for the heads up! You can bet I will be checking tomorrow when it is light.
/ Check your motor mounts #3
I try and give my tractor a quick look every once in a while for loose or missing bolts but so easy to miss stuff, will have a look tomorrow. Thanks for the pic as well. :thumbsup:
/ Check your motor mounts #5
Thanks Islandtractor will check this week end as I also wrap rest of my hoses that pass through channel openings.:D
Interesting note: after calling my dealer for a replacement bolt, they needed to know 1) which side of the tractor and 2) specifically which of the four bolts was missing. Apparently these motor mount bolts are not all the same even on the same tractor. I think the parts guy told me there were three different sizes on one tractor even though all the heads are 19mm and look the same. :confused: Weird.
/ Check your motor mounts #7
The lengths are all different, I doubt the diameter is different. I have had one missing since the tractor was new. The dealer gave me a replacement bolt that was too long.
I'm sure you are right. The bolt heads are all 19mm.
Washers???
/ Check your motor mounts #9
There is also a lock washer coming to you.;)
Make sure you use red lock-tite when installing them.
Thanks Rick. Glad to know your orange team is still working to support us even though you now seem fascinated by those weird albino tractors these days.
/ Check your motor mounts #11
Red lock-tite not the blue?! The last time I used red lock-tite on a large bolt I had to use a OA torch to loosen it up for removal!! I use more blue now, but if blue problematic for these I guess I will reconsider.
I presume red as blue loosens more easily with heat and we are talking about the engine block.
/ Check your motor mounts #13
I'll be going through my machine next time out
Joel
Thanks for the post the picture left an impression
Update:
First, a thanks to the mechanics and parts guys at Wallace Tractor for advice and a replacement bolt. I had a little trouble getting the replacement bolt started but at their suggestion cleaning it up a bit with a 14mm die solved that problem nicely. Thanks guys.
Second, as the Wallace team pointed out, the loose/missing bolt was not a motor mount but rather the loader support bracket attach point to the motor.
Third, on review of the KL401 owners manual there are clear instructions to retorque those bolts every 25 hours. Oops. I wonder how many of us are doing that. Until now I certainly hadn't even looked at the manual in oh maybe 225hrs or to be precise on the delivery day that Rick drove it off his trailer.
Fourth, the manual lists the appropriate torque specs. However it is a real btch to get 120 ft pounds of torque while on your knees and reaching under the tractor with one arm.
Fifth, use red locktite
Sixth, I promise to retorque these and other bolts at least every time I change the oil and I'll try to remember every 25hrs.
/ Check your motor mounts #15
Update:
I have consulted the owner manual several times but somehow missed the 25 hours retorque task. Red locktite it is.
/ Check your motor mounts #16
If using red loctite would retorqueing break the loctite?
Does loctite dry to crispy dry or retain some flexibility?
I'm glad this post continues as I forgot again this weekend to got through my bolts
Good questions Joel.
I suppose that if retorquing causes some movement of the bolt then perhaps it would be best to pull it out, clean it, and put on more loctite. In theory the bolt should not move though and therefore one would not need to go through this scenario.
What I might do is retorque the bolts to slightly less than I tightened them originally (the manual has a range of acceptable torque) and figure that if it moves with the lower range torque setting then clearly the loctite did not hold anyway so I might as well remove the bolt and start over.
/ Check your motor mounts #18
Your plan makes perfect sense to me
Loose bolts can do a lot of damage that is not easily repaired
Joel
/ Check your motor mounts #19
I don't know if your loader is designed the same as the one on my CK20HST (KL120) but if it has the tie across the loader uprights or 'stanchions' then you might want to resolve the issue that I ran into BEFORE you retighten the loader uprights where they bolt to the casting.
My CK20HST loader got 'unlevel' after about 30 hours of use ..... turns out that the stanchion mount on the left side had a stripped bolt where it contacts the trans. casting. My dealer took it in and re-tapped the bolt hole to the next size larger .... end of problem .... kind of. At about 40 hours I removed the connecting member between the stanchions (over the back edge of the hood) to install one with extra length for installation of an EZ-GO golf car sunshade .... the bolts immediately 'bound up' and had to be screwed out, even though the holes in the stanchions and connecting member are oversized for clearance on the bolts .... the holes on the stanchions were about a bolt hole off (too close together) for the connector hole spacing so I adjusted for that when I made the new piece. It seems as though Kioti got the holes off for the width of the FEL frame/trans. casting causing a mismatch which may have resulted in the stripped casting hole upon initial assembly ....
You can see this connecting member in the photo pretty well ....
CK20S EZ-GO - TractorByNet.com Photo Gallery
/ Check your motor mounts #20
When I bought my CK30 used several years ago a couple of the front loader mount bolts were missing and some were very loose. I ordered a complete set of bolts but I could not torque the front lower ones all the way because the holes were partially stripped. I put red locktight on them and torqued them as far as I could without stripping them further. I haven't torqued them again and so far they appear to be holding. I am reluctant to drill out and retap because the holes are rather shallow and I don't want to chance drilling too far into the motor. I occasionally check for movement there. So far I haven't seen any. I'm afraid if I retorque the problem bolts they will just strip out more. I am also concerned that a tap will not be able to rethread to the bottom of the relatively shallow hole since taps are tapered.
2018 Bobcat MT55 (A64126)
2018 Bobcat MT55...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2005 Trail-Eze TE70HT53 54ft. 42 Ton Hydratail T/A Drop Deck Trailer (A61573)
2005 Trail-Eze...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
