"The" Un-Safe Tractor Operation Thread
/ "The" Un-Safe Tractor Operation Thread #1
beppington
Elite Member
of my
Here
aka "Tractor As I Say, Not As I Do"
aka "Confessions of a Tractor Dare Devil"
aka "I Know This Ain't Smart, But I'm Doin' It Anyway"
aka "I Did _____ & Am Surpisingly Still Alive To Tell About It"
I couldn't find where one already exists, so maybe it'd be good to list what you've done with your tractor that isn't safe ... Maybe you still do it; Maybe you learned a lesson - Tell your story here!
Mine:
1) I was pulling out a bunch of close-together saplings (a little too big for the rotary cutter) with a chain by myself. Rather than jump back & forth on & off the tractor every time I yanked one out to un-hook the last one & re-hook the next one, I realized that while I'm standing beside the tractor I can just reach my hand over & press the HST pedal to back it up to the next tree to be yanked. (Yes, I have my seat safety switch bypassed (jumpered) ... which should probably be #2 below :)) I am aware the tractor could run over me when I do this.
2) I have a ROPS but have never once even tried my seat belt :shocked: I assume it's under the seat somewhere :confused:
/ "The" Un-Safe Tractor Operation Thread #3
Well see....here's the thing...I am gulity too...but here is my excuse..I have many Pecan trees all over my pastures and many low branches that I do not want to cut so I bush hog with my ROPS folded down..so I do not wear my seat belt at all..ever...
/ "The" Un-Safe Tractor Operation Thread #4
I sometimes walk under the raised FEL..sudden hose failure would be bad
When chaining stuff to the FEL, I sometimes step in FEL while hooking chains to hooks...recently moved an overhead diesel tank, for example
I use seat belt only when doing extremely heavily lifting, either front or rear, on an obviously risky slope, pulling very heavy using tow bar.
/ "The" Un-Safe Tractor Operation Thread #5
As for the seat belt thing I don't believe it can be promised one way or the other as to how much safer they make a person. I have seen issues were a seat belt may have helped and I've seen just as many were they could easily cause harm. I never wear a seat belt when on a tractor and probably never will. I do however wear one on the skid steer, to easy to fly forward in that type of machine.
I have over worked machinery, taken them way past they're expected ranges. I 've moved logs with a front end loader while the back wheels didn't touch the ground. I also have walked under hydraulic pieces{FEL BH etc.} one line pops and they will come down way faster then anyone can move. I have pulled trees with front wheels off the ground with no type of ROP. I have run a chainsaw with one hand, in shorts and flip floop type shoes. I do not do this type of stuff any longer, but when I was young I was invincible,.,.,. weren't we all.
It would be interesting to have a Kubota engineer or designer watch me, or any of you with your brand's engineer/ designer, using the tractor without me knowing it, & have him (her?) constantly & honestly grading me on an "acceptable" rating while I'm using it. Scale of 1 to 10; 10 is 100% acceptable, one is "You're about to die" or "I can't believe the tractor hasn't broken yet".
As I'm driving along a dirt road at a safe speed doing no actual tractor "work", & wearing my seat belt (tho I never do), maybe I'd get a 9.9 or 10. If I'm bushhogging a field, wearing my seat belt but going a little too fast, maybe I'd get a 7 or 8. No seat belt, trying to push over a big tree with the FEL, the FEL slides up the tree & the front wheels come off the ground, maybe I'm down to a 4. Standing beside my seat-safety-switch-bypassed tractor pressing the HST pedal to move it while I'm not on it, maybe I'm down to a 3. Chain wrapped around the FEL bucket & a fence post I'm pulling out, & I'm operating the FEL controller from beside the tractor, lifting hard until the rear wheels come off the ground, maybe I'm down to a 3? I don't think I've done any 1's yet.
/ "The" Un-Safe Tractor Operation Thread #7
never wear my seat belt while mowing. takes too much time to get off pick up an empty beer bottle.
/ "The" Un-Safe Tractor Operation Thread #8
... No seat belt, trying to push over a big tree with the FEL, the FEL slides up the tree & the front wheels come off the ground...
You mean this is NOT the norm for tree removal? :eek:
/ "The" Un-Safe Tractor Operation Thread #9
I always wear my seatbelt while mowing my lot due to several elevation changes, berms, and mowing on the uphill side of a 3' tall post rock retaining wall. Glad I had it on last mowing when I speared a half submerged railroad tie with the FEL. The seat belt kept me from being thrown into the steering wheel.
About the only time I don't use the belt is when I push snow with the back blade.
/ "The" Un-Safe Tractor Operation Thread #10
beppington, if your rear wheels come off ground when FEL is chained down, it's a sign that you would benefit from more rear weight... would not only certainly let you get the max out your FEL lift capacity thus likely pulling more stuff up, but would be safer while doing it as well. You do want to let your tractor be all it can be, don't you:thumbsup:
Tires are already filled, just didn't have box blade or bush hog on the back.
/ "The" Un-Safe Tractor Operation Thread #12
There's a thread called dumb things I did w my tractor in (I think) Owning/Operating
/ "The" Un-Safe Tractor Operation Thread #13
Reading about the problems of conscience you get with seat belts, I'm glad tractors sold in this country don't have seat belts. You get fined though if you don't use one in a car...
/ "The" Un-Safe Tractor Operation Thread #14
How about riding in the FEL tree trimming while your buddy drives you around the land. Also useing it to hang christmas lights around the house. Im guilty.:laughing:
/ "The" Un-Safe Tractor Operation Thread #15
Yeah, or standing in the FEL throwing bundles of shingles up on a roof.
Here's one I learned from my grandfather. Pull-starting one tractor with another while alone:
1. Chain tractor A to tractor B.
2. Place tractor B in gear.
3. Get on A and pull B until B starts.
4. Put A in neutral and jump off while it's rolling to a stop.
5. Run back and hop on B, get it in neutral and stop it.
Oddly enough, nobody was ever killed on my grandfather's farm.
/ "The" Un-Safe Tractor Operation Thread #16
Ah, but we are not our grandfathers. How many of us could hand start an old John Deere by spinning the flywheel or hand crank one of the other models to life. They were truly a tough bunch that did things of which we can only imagine. My hat is off to them.
/ "The" Un-Safe Tractor Operation Thread #17
Ah, but I have performed that tractor-starting feat. I learned it from my grandfather, but he had this old Deutz with a bad starter and if it didn't start rolling down the hill, you still had to get it going.
And I have hand-cranked a Cockshutt 30 to life. It wasn't necessary, that being the tractor that always started, but we found the hand crank and just had to try it.
/ "The" Un-Safe Tractor Operation Thread #18
I would wager you are in the minority.
I have also done this in my youth, but time and tide have taken their toll. I remember when we got our first car that didn't have a hand crank for backup, boy were we mad.
/ "The" Un-Safe Tractor Operation Thread #20
My wife trimmed the rhododendron bush, while standing in the FEL, using a broom to operate the joystick, with no weight on back of tractor, and no fluid in the tires.
This was with the GC2410 I have now.
Does that classify as a 1 or 2 or 3 on the rating system?
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
CATERPILLAR D5K2...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
2015 Hitachi ZX210LC Hydraulic Excavator (A61572)
2015 Hitachi...
LEEBOY CHALLENGER 7 SWEEPER (A64279)
LEEBOY CHALLENGER...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
