DK65C Glow Plugs
/ DK65C Glow Plugs #1
pjf
Member
Hello
I have a DK65C that starts fine but when I turn the key to the "on" position the glow plug indicator bulb does not light up. How can I determine if it is just a bulb or if the glow plugs are not working?
Thanks
/ DK65C Glow Plugs #2
There are a number of ways depending what tools you have.
1] Take the bulb out and test it using the tractors battery. One wire to the brass case of the base and one wire to the center post on the base. The wires go to the battery posts.
2] If you have a volt meter, set the scale to 20 volts and connect the Red led to the wire/buss that feeds the plugs and the Black led to frame ground. You should see about 12 v with the plugs activated.
/ DK65C Glow Plugs #3
Turn to on, wait 20 sec, if it starts promptly its not the plugs.
My '87 Japanese MF didn't even have a light and that was the procedure for starting it. Worked every time.
/ DK65C Glow Plugs #4
Hello
Thanks
Since it starts fine, I would say you have a bad bulb.
2013 GMC (A62613)
2013 GMC (A62613)
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2004 John Deere 8320 (A63688)
2004 John Deere...
429888 (A61165)
429888 (A61165)
John Deere 825I (A64127)
John Deere 825I...
