How are GOOD trailers wired?
/ How are GOOD trailers wired? #1
Verticaltrx
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I'm working on building a heavy duty 5x10 utility trailer and I'm getting close to wiring it. I don't want to go cheap here since it seems like every other trailer I own the wiring is crap, lights work intermittently, and every time they have to be inspected I have to fix numerous connections, etc.
So, what is the preferred method for wiring a trailer? A couple things I can think of is to run every thing in conduit and avoid using any scotch lock connectors (solder everything I guess). Any other tips, pics, etc of good quality trailer wiring or how yall wired trailers you built would be great.
Thanks.
/ How are GOOD trailers wired? #2
Thanks.
That's it. Soldered connections and pvc conduit with elbows etc.
That's how my Pace is wired.
/ How are GOOD trailers wired? #3
I will add:
Heat shrink all soldered connections with a marine grade heat shrink that has a glue in it that make a water tight seal and bring all grounds back to a central point.
Chris
/ How are GOOD trailers wired? #4
The main thing I have found that helped on a utility trailer I had was to run a ground wire to all the lights. Don't rely on the trailer frame as a ground for the lights that are bolted/screwed on. After in stalling wiring that contained a ground wire I have not had any issues.
/ How are GOOD trailers wired? #5
Conduit is overkill, and not at all necessary.
Just solder and shrink.
All grounds should be via wire, running back to the tow vehicle, no chassy grounds.
/ How are GOOD trailers wired? #6
You must not use your trailer as I do and many of my customers. I get wires ripped out and off brought to me monthly from folks driving in tall grass, weeds, in the woods, ect.
Grey plastic 1/2" conduit is cheap and can be bent to about any shape with a little heat. To cheap not to use when re-wiring a trailer.
Chris
Wow, thanks for all the quick replies. I hadn't thought of using PVC conduit, I was planing on using 1/2" pipe welded to the frame, but PVC would be easier.
I plan on using the trailer behind my tractors 75% of the time for hauling fence posts out in the field and firewood in the woods. So having the wiring protected is pretty important.
I'll also look into running a ground to every light.
/ How are GOOD trailers wired? #8
Cage your lights too or build them into a metal box and go with LED lights.
Standard bulbs are always burning out I found and the connection gets weak over time and if the lights are at all exposed you'll rip one off sooner or later.
Don't forget a tube of dielectric grease for the harness connection to whatever you're connecting it too....tractor or vehicle.
Or sometimes I use Fluid Film.....great stuff.
/ How are GOOD trailers wired? #9
Chris
My mistake, I thought it was common sense to run them where they can't easily get damaged.
/ How are GOOD trailers wired? #10
All good advise. Especially the caging of the lights since he is going to be using it in the woods.
Chris
/ How are GOOD trailers wired? #11
WITHOUT scotch blocks. :mad:
/ How are GOOD trailers wired? #12
Buy good quality trailer wiring that is one continuous piece from the truck plug to the lights. Never a break, never a scotch lock, never a splice.
I run my 5x10 homemade trailer in the woods, over trees, rocks, tops, etc all the time. The wire was run inside 3/4" thick wall square tube that was welded to the bottom of the frame. Why? I foresaw the damage from having repaired lots of wires! The wire inside the tube is inside plastic spiral protector. No chaffing, no shorting.
I put the lights on the back of the fenders with angled cage under them that doubles as a step and protects the fenders from getting bent onto the tires. When I back into things the lights are protected and the trailer just bounces off. I say "when" as it's just a matter of when and how much damage will be done.
If you are still collecting parts, get a torsion sprung axle. Greater clearance as there is NO cross shaft hanging down low to get hung on stumps, etc. Also fewer parts to deal with and maintain. It's been towed for 12-14 years now and only had one failure. Crossed a dry creek with a full load and the tongue got bent because it wasn't built strongly enough (oops). It is now. The lights and wires are still original but new bulbs have been swapped in.
/ How are GOOD trailers wired? #13
From my experience working at a trailer rental as a youngin' :
Solder all connections
Most problems are due to a bad ground. Run a separate ground wire or solder all grounds to the chassis. (Yes you can solder copper to steel)
Cage tail light and protect pig tail at tongue from pinching and pulling.
/ How are GOOD trailers wired? #14
I cannot agree more. Most problems are due to a bad ground. Most problems are due to a bad ground. Most problems are due to a bad ground.
Wierd things happen with lights and bad grounds. I KNOW this... and it still trips me up sometimes. (I will approach a problem the wrong way because I THINK I am more experienced and know better. Turns out "back to basics" works every time!)
Running a separate ground wire to each device is a GREAT idea. I am currently fixing a problem associated with just that. I have a trailer with a tilt bed. (Basic single-axle 5x10.) The ground wire from the tow vehicle is anchored to the trailer chassic OK.. but what I finally figured out is the pivot-point of the trailer is rusty. The trailer is basically two pieces. The ground wire is on one piece and the lights are on the other.
/ How are GOOD trailers wired? #15
All great ideas, however, I see and have no problem with grounding to the frame (4 different trailers 2 of which I wired), it is a fine conductor. Just connect properly with bolts and star lock washers.
The problem I do see with relying on the frame is not running a ground wire from the truck connector to the frame and relying on the ball or pintle, this will give intermittant problems everytime!
Just my .02!
/ How are GOOD trailers wired? #16
Thanks.
Yup just like that conduit,watertight junction box's,solder and shrink and use a good multi-strand insulated trailer wire, I like having extra wires in mine just because...and have the pig tail removable up front (junction box) because it will get replaced the most from my experience anyway. hth :thumbsup:
/ How are GOOD trailers wired? #17
Just my .02!
That should work... until you get into the situation I mentioned. In that case, you (I) have to add another ground strap from one piece of the trailer to the other.
Also, you gotta make sure your lights are grounded good too. Mine aren't so I am going to start from scratch and do it right. I have been putting this off for quite some time! :thumbsup:
/ How are GOOD trailers wired? #18
I prefer metal conduit for the wiring, welded to the frame. Also agree on grounding to the frame, as long as you have good contact to a clean spot on the frame, no problems. Three of my four trailers are wired this way, the fourth (a small Snowco) is wired through the frame tubing. ~~ grnspot110
/ How are GOOD trailers wired? #19
led lights are great due to decreased load.. less power.. less grounding issues.
everyone has seen the blinking brake lamps and pulsing e-brake problems.. along with the standard/ bad ground..
I go overkill.. clean metal on chassie with ground there AND ground to each lamp.. ie.. chassie is parallel.. then of course.. paint over after the connection is made.
soundguy
/ How are GOOD trailers wired? #20
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2003 CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
2003 CASE 590...
KING 3 BAR - 18 SHANK CHISEL PLOW, 3PT (A64278)
KING 3 BAR - 18...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
