ceiling fan
/ ceiling fan #1
tglass
3320 w/cab
Is there an easy way to clean a ceiling fan without dropping all the dust and whatever all over everything underneath? Yes this is embarassing to ask, and no, my place is not filthy, but when someone has just washed the sheets and bed spread...well someone is going to catch more than the dust and clean the fan blades. Guess who is on the wrong end of the fan?
/ ceiling fan #2
Vacuum sucking while dusting.or wet cleaning rag w/small trash can below as you wipe.
/ ceiling fan #3
I use a damp cloth and wipe the blades with it. If I'm careful it will all stay on the cloth. You could hold some newspaper or cardboard underneath if you are afraid some will drop. Using a wood stove nearby seems to coat our fan with dust :mad: so the blades get cleaned several times a year.
/ ceiling fan #8
you could remove each of the 3 screws holding on the 5 blades then take them outside hose-um-off:D although you did mention " easy way" so I'd go for the shopvac and the fan cleaner attachment,:thumbsup:
/ ceiling fan #10
you had to make me look at mine. they need cleaned. :laughing:
I use a damp paper towel.
/ ceiling fan #11
Don't clean the bedding....problem solved.:laughing:
/ ceiling fan #12
I use Wipe by Clorox. They are damp cloths with windex or I think the other type has bleach in it, that are great for dusting and cleaning up messes. I clean my blades a few times a year, and never noticed it being that difficult with them. It takes a Wipe to do a blade, because they are such massive dust collectors.
Eddie
2013 5x8 Port City S/A Enclosed Cargo Trailer (A66738)
2013 5x8 Port City...
2012 SPARTAN GLADIATOR FIRE TRUCK (A66091)
2012 SPARTAN...
2011 PREMIER PUMP AND POWER 3HC-DM16 TOWABLE DIESEL PUMP UNIT (A67714)
2011 PREMIER PUMP...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
