Fully Loaded
/ Fully Loaded #1
tsteahr
Gold Member
CT shoreline
Massey Ferguson GC2410tlb w/ R1 and Rimguard
Took a drive to the dealer yesterday. Brought my front tires with me to get loaded with Rimguard. I've had this on my mind since I got my GC2410 TLB. When I go up a fairly steep slope, the front can get light enough so I can't turn the tractor. Front tires are coming of the ground. I suspect the 50 lbs of thumb welded on the bh contributes to this.
Now I know the front tires on a scut are tiny. But I figured every little bit helps, right? Got em filled, probably a little over 2 gallons in each tire. I'm guessing each tire was about 25lbs heavier after the fill.
Fired up the tractor today, headed for the same slope and sure enough, I now had just that little bit extra weight to keep the front tires on the ground so I could steer. :cool2:
So I can say loading the fronts of a scut won't transform the machine, but in certain situations it is noticeable. And the best part was the bill at the dealer came to $10 :thumbsup:
/ Fully Loaded #2
Glad it worked out for you. Results for 10 bucks is hard to come by now days. :thumbsup:
/ Fully Loaded #3
$10 heck of deal. :)
Maybe dirt in bucket might help w/more traction..off set BH.
/ Fully Loaded #4
Do you have l/r split brakes? You can very effectively augment steering with those.
larry
/ Fully Loaded
larry
I wish I did. These little SCUTs don't have split breaks.
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
King Kutter 7' Lift Kutter Rotary Mower (A66408)
King Kutter 7'...
2024 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
39' 9" 3-Bar Drag Tooth Harrow (A66285)
39' 9" 3-Bar Drag...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
