L3240 Oil Change
/ L3240 Oil Change #1
Agrantina
West Tennessee
Kubota L3240 GST
I am going to do my 50hr service this week. Manual says to change engine oil and filter and hydraculic filter.
I plan on using rotella 15w-40 T.. I live in West TN and tractor will not be used much in the winter- but kept in heated garage. So I beleive that 15w-40 will be fine. When replacing the hyd filter I am reading I will lose some fluid- so I guess that UDT is what is in it now so top off with Kubota UDT..how much do I need to buy a qt?
1. 15w-40 ok?
2. Top off Hydraulic with UDT?
3. How much UDT do I need to buy?
AndyG
/ L3240 Oil Change #2
Don't forget to drain both sides of the engine oil pan. Hint, hint.
/ L3240 Oil Change
:thumbsup: thanks- I noticed that it had a C cup size on both sides:D
/ L3240 Oil Change #4
Your tractor should have SUDT in it, confirm with dealer. At my 50 hour service I replaced all filters. I also changed trans/hyd fluid and front axle fluid, used SUDT. My preference for engine oil is Mobil 1 5w-40. If you are a Shell guy, they also make a Rotella 5w-40.
To answer your questions:
1) Yes, as long as it meets your minimum starting ambient requirements. Would not for me in central Indiana.
2) I don't think so, should be SUDT. Confirm with dealer.
3) I don't know since I just drained all my fluid.
Philip.
/ L3240 Oil Change #5
Is SUDT used in DT and GST tractors or is it only used in HST tractors?
/ L3240 Oil Change #6
At 200 hrs. I changed the hydraulic filter on my 3240 without losing a drop of UDT.
I just parked the tractor sideways on a slope, spun the old one off and the new one on.
Not a drop lost then and didn't have to change/add fluid till 400 (few days ago).
/ L3240 Oil Change #8
FYI, On my first filter change, one of the filters, can not remember if it was hst or hydraulic, I could not get off with a filter strap. Worked and cussed on it for 5 long minutes. I then noticed at the metal base of the filter were machined notches in it. Put a big strong screw driver in the notches and use a hammer to loosen. Philip.
/ L3240 Oil Change #9
If you have an HST transmission, your tractor may have both hydraulic and HST filters, and they are not identical. Get them switched and you will pump the entire hydraulic reservior out on the ground in about 30 seconds.
/ L3240 Oil Change #10
I just did my 2920 this past week. Lost less than 1 qt. of hydraulic oil. I had bought 2 qts. at the dealer not knowing how that would go. The advice about not getting the 2 filters confused is good...it took me a few minutes studying the manual (which doesn't really have very good illustrations) to figure it out. My filters weren't all that hard to remove, but I had bought the filter pliers someone here suggested and they really work great, even though I cheaped out and got the HF version.
/ L3240 Oil Change
thanks- I have the GST- so I just have the one hydr filter. I sure thought I would lose more than what you guys are talking about.. I will pick up 2 qt SUDT and may not even open the 2nd one:thumbsup:
So the 15w-40 rotella T is fine?
AndyG
Caterpillar 906M (A53317)
Caterpillar 906M...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
PEMBERTON INC CAT 924H 42" WHEEL LOADER FORKS (A60429)
PEMBERTON INC CAT...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
