Turbo Charger
/ Turbo Charger #1
doc623
I have a JD 1050 4 x 4 and was wondering about the benefit of adding a tubor charger.
Any comments/suggestions?
/ Turbo Charger #2
Turbo charging provides more hp and yields a 30% saving on fuel. However, your engine needs to be designed for it. Usually, the compression ratio is reduced some to avoid having too much combustion pressure with the turbo. Probably a bunch of other issues to deal with, too.
Ralph
/ Turbo Charger
Thanks for the response.
How do I find out the particulars?
/ Turbo Charger #4
Just do a search on the internet...wealth of infomation available.
Unless you want to get inside the engine (new pistons and maybe rings), keep your power increase modest. You may have to adjust the injection pump too.
This can be done if you're reasonably good with a wrench and, as mentioned, keep the expected power increase modest.
/ Turbo Charger #5
A modest boost in intake pressure and you will not need to do anything to the engine. Usually any boost pressures under 7psi will not harm anything. Problems occur when you start boosting fuel delivery and boost pressures.
/ Turbo Charger #6
All the 1050s I have ever seen have a turbo. did somebody steel yours?
/ Turbo Charger #7
That is true. All 1050's were built with turbos. If you don't have one, I would suspect someone swapped in a different engine from another model.
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2017 Gehl RS6-34 (A64119)
2017 Gehl RS6-34...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
