Hydraulics re John Deere 2440
/ Hydraulics re John Deere 2440 #1
BenPolasek
John Deere 2440
Is there an online maintenance/owner's manual for a John Deere 2440? If so, where? I specifically need to know the quantitiy of hydraulic oil needed by this tractor to replace/purge hydraulic oil that has become contaminated with water. Also where's the best place to get a hydraulic oil filter? I do have a front end bucket mounted.
Thanks!
/ Hydraulics re John Deere 2440 #2
Welcome to TBN:D
You can buy the owners manual and service manual from JD...not sure how much fluid she needs, sorry.
/ Hydraulics re John Deere 2440 #3
My JD 2030 takes 10 gallons, yours should be close. I only use JD filters, but you could try NAPA for some possible savings.
/ Hydraulics re John Deere 2440 #4
if you use jd oil and filters and one fails you have a case against jd
if you use another brand jd will tell you to sue them
