Where do you keep your firewood?
/ Where do you keep your firewood? #1
irwin
SE Conn
2004 Kubota L35TLB, '89' Cub Cadet 1541
Been thinking about building a woodshed.
The problem is I'm already close to max with the other necesary jobs that have to be done... and I work 5 days, so it's only 2 days a week to do it all in... Sometimes I force myself to do more than the necessary after work chores, but at my age (mid-fifties) 10-11 hours of work in one day pretty much does me in..:D
I hoping to get some very inexpensive, easy-to-do ideas, something that'll hold 6-9 cords. I have more cut, but I like to leave it outside in the sun and elements for at least the first 4 or 5 months.
/ Where do you keep your firewood? #2
Irwin.......What are you trying to protect it from? I suppose the snow situation is vastly different there than here in N.W. Ga. Can't imagine having to go out and clean off feet or inches of snow to get to my wood. Here, I just the other day went out and covered my supply with several tarps. NO, I dont let it cover the sides, just over the top and down perhaps a foot or so on the edges. The wood needs to breathe still and if I cover the sides it actually gains moisture it seems..........
Anyway, had my first fires last week as the night time temps were down in the lower 40's. Just about ran us out on Wednesday night as it was in the 50's and my new Harman top loader puts out so much more heat than the ol Waterford Ashling.......At least it was one way of getting my wife "hot" that night........God bless......Dennis
/ Where do you keep your firewood? #3
Weather here is 90% from the SW. On the NE side of my pole barn I built a 12' x 30' wing, closed the ends, put vents in the ends, divided it into 5 sections and used upright 1x6 oak to build partitions that create those 5 sections...leaving spaces between the upright 1x6s for circulation. Wood dries fairly well in this wing, and stays dry....I use pallets on the ground to stack it. It is convenient to get into as the whole face is open. Wing roof does have app. 18" overhang which helps protect it, and is only 7' high at the edge.....just enough to comfortably walk under the 2x10 runner that is on the poles. App. 8-1/2' high at the rear. I use one bay for lawn stuff, and get app. 2.5-3 cords in each of the other 4 bays.
/ Where do you keep your firewood? #4
I have a 6'x12' garden shed. It's on a stone foundation. On the back side (the wide side) I poured footings and built a platform and then extended the rake end of the roof by about 4'. The shed looks like a salt box now. Works fine.
A neighbor recently had somone in to build a wood shed. It's a free standing platform with a gable roof above. Looks great.
Keeping the firewood clear of ice and snow is a big plus IMO.
/ Where do you keep your firewood? #5
There's thread couple weeks back on this topic,lot great ideas w/pics.
"but at my age (mid-fifties) 10-11 hours of work in one day pretty much does me in.."
I hear that,gotta start pacing yourself. ;)
/ Where do you keep your firewood? #6
For years I piled it on skids and put old tin sheets on top. It was fine.
I know have a woodshed, it cost about $200 because I used salvage tin. Took about a day and a half to build. It's been up probably 10 years almost now and is just like new. The good part is when it's only part full of wood, I can put other stuff in it.
/ Where do you keep your firewood? #7
If you are short on time now just stack it on pellets and cover the top with something that keeps the water off. Be sure to do this some place where you don't want to build a shed. If you happen to have a free day (I know they are tough to come by) then you can start working on it. If you do build a shed I would suggest to add another 5-6 feet (width or length) more then you need. That will be useful space to store related tools or to work out of the elements
I have enough space under my garage for 8 cords but I only need about half of that each year. So. I stack 4 cords on one side and as the time approaches - right about this time - I start cutting wood to fill up the other side. The extra space for my setup is in the middle so I can stack wood even is we have a snow or a rain storm. This way by the end of March I have the firewood all cut and split for the next Winter.
/ Where do you keep your firewood? #8
There is always one course of action, don't do anything. I assume you just stakc it up outside in the open. That has worked for me for years. I know it's not ideal, but it gets exposed to the sun and dries out well. You just have to put up with some snow on it and the fact it get wet at times.
/ Where do you keep your firewood? #9
I handle the wood once from the splitter directly onto pallets. Fork lift the pallets to storage/drying area stacked two high. Add a used-rubber roofing sheet to the top to shed water and melting snow.
After two years, fork-lift the pallets from the storage/drying area into the garage where it goes into the woodburner. Anything to cut down on the multiple times handling a piece of wood (used to be I'd recognize some of the pieces when throwing them into the burner, and thought that was just too many times picking it up). :D
/ Where do you keep your firewood? #10
That sounds all to familiar but I still have to handle each piece of wood about three times.
Thanks guy's...
Yes' I throw a tarp over each pile that's ready for use.. the problem with this set up (as has been noted) is snow and ice. I like the idea of a long 10-12 foot deep, 10 foot high open face building..like a horse run-in shed with a vented eave in back. Similar to jimmyj's picture..
I've never built one but I can think of some draw backs of going cheap.. wood rot (the building not the firewood) at ground level is one... the fix would be... pay up $$$$. Concrete pad, or some other ground prep that allows for quick drainage, metal supports, or pressure treated wood.
Another drawback would be looks.. not that I care what a building that no one can see looks like,,, but the wood shed will need to be within an easy walk from the back door.. this means in my side yard. The side yard is visible from the road and is used for outdoor get togethers.. we want that yard looking better than a scrap area. A good looking open faced building would be acceptable.
Anyone have plans for that style building? Say the building in the first picture instead of the second..:D I do like the first shed but I'd need to double the length, and get rid of anything that adds too much cost. Say having to buy a wood mill to make my own siding pieces would be out of the question. :laughing:
/ Where do you keep your firewood? #12
I'm trying something new this year. I'm putting my firewood in large breathable bags that can hold almost a half cord. They are 36"x42"x58" high, with 10" lifting straps and will hold 2200 lbs. I hold them open with the forks on my loader and fill them. They fit on a pallet which I then bring into my garage. Garage is attached to house so no need to go out into the weather to get wood. I have 12 foot ceiling in my garage and can stack them two high. Oh yea, they are reusable.
/ Where do you keep your firewood? #13
Jake
Where do you find the bags?
Idea seems fine, to the point of getting the firewood out of the bags.
I just see that as a real hassle.
But will be looking for a report and some pics as to how it works for you.
For loading, do you toss the pieces up and in the bag and just let them fall haphazard, or try some semblence of stacking the wood?
How high is the header on your garage door? Or do you carry them in on the pallet, without the bag tipping over?
/ Where do you keep your firewood? #14
Thanks guy's...
I am sure, if you have the logs, that you can brinig in a band saw guy who would mill the logs for you. I have had this done 4 times in the past 12 years.
Then you can use the lumber to build you wood shed.
/ Where do you keep your firewood? #15
My Holz Hausen! :)
First pic is the ring 10' in diameter.
Second pic is paint mark at 8'.
Third pic is first course of split wood at an angle inward.
Fourth pic is several courses of split wood angled inward and internal area of circle with wood both split and small unsplit pieces stacked vertically.
After it was about 3' high I put another course of shims around the outside ring to keep the wood angled in and continued.
According to the instructions, if you stack green wood 10' high and let it shrink down to the 8' mark on the pole, it is dry and ready to use. Since I started with mostly dry wood, I just stopped at 8'.
1 cord of wood is 128 cubic feet of wood.
A pile 10' in diameter and 8' tall contains 628 cubic feet of wood, or, a tad over 4.9 cords. If you would stack it 10' it would be a tad over 6 cords.
It looks nice, takes up less room, and is kinda fun to build.
I liked it so much last year, that I build another one this year. However, this year I just tossed the wood in the center, not stacking it vertically as last year. I keep a tarp over the top, only so the sides can breathe. I cut a hole in an old tarp and slid it down over the center pole. Works great. :thumbsup:
/ Where do you keep your firewood? #16
I ran across this a while back. I thought it was cute.
/ Where do you keep your firewood? #17
Very cute Larry. What a cool idea!
/ Where do you keep your firewood? #18
+2 on where did you get the bags? Price?
I'm thinking about going with them too but have a concern. I can see where they would work well for split rounds. But what about smaller branches and things that have "points" on them? Would those tear the bags? I'm assuming they would.
/ Where do you keep your firewood? #19
Here are some pics of my wood and my shed that i built at the end of last winter for my wood. I basically dump it off and split it one ranger truck load at the time and let it sit sometimes for a while in the sun then i stack it, but again i dont have this down as this is the first fire season with the shed, before i would just pull a tarp over the pile before a rain if i remembered. I built the shed with treated 4x4s. front were 4x4x10s and the back were 4x4x8. the headers were 2x8x16s. The rafters were 2 pieced togeather pieces, not the correct way but i was saving money and can always reinforce if needed but we had a 5 inch wet snow and its fine as well as me on top . Most of them are treated but not all and the stickers that the tin is screwed to is treated wood purchased for the shed. The tin was scavanged from helping a coworker tear down his shed. The 4 posts 2 headers and the stickers and cement cost me $200ish dollars but i really cant remember, that is all i bought for this shed too. It is 16ft x 12ft under the tin. Yea in a driving rain most will have wet ends but not all of it. i built it for wood and for other stuff when needed as you can see.
Sorry for the quality but they are cell pics.
/ Where do you keep your firewood? #20
@clemsonfor - you may want to reinforce your shed. The last photo shows a giant thumb hovering over the shed. It it were to drop, the shed may be crushed... :)
Mike
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
DRUMS ON PALLET (A63291)
DRUMS ON PALLET...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
Caterpillar IT14G Parts Manual (A63117)
Caterpillar IT14G...
