Equipment Trailer Question
/ Equipment Trailer Question #1
deere5105
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I have been watching and looking for a deal on a used trailer. Minimum length is 20' and a minimum of 12K rating. I am not looking for stand up ramps as I am concerned they will get in the way of longer loads hanging over the end. My MX6 cutter with FEL installed is about 24' in length. This would be the longest anticipated load. I found this 22' trailer rated for 14K on craigslist. I like the over the fender style. Can pull 8' disk on this trailer without having to let it hang off the back. Asking price on this unit is $2450. I am a little concerned about the pintle hitch. Will be towing JD 5303 MFWD with Ford F150. 5303 is a recent purchase and towed it approximately 400 miles with this truck and borrowed car hauler style trailer. Had no problems pulling it. Looking for some feed back on this style trailer. Will try to post side pictures. File currently too large. Thanks.
/ Equipment Trailer Question #2
That is a lot of trailer for a F-150. I have no doubt a newer one will do the job if equipped right so if the trailer is decent and the price is right jump on it. I would offer $2000 cash. If he does not take it walk and he will be calling you by the end of the day.
Chris
/ Equipment Trailer Question #3
You can get a hitch ball that will accept a pintle hitch for your truck's 2" receiver. I like these because you can still use it with a traditional 2" trailer coupler as well as a pintle hitch.
What I don't get is why you want a 12k-14k trailer to haul behind a F-150 that probably has a tow rating of 8-10k lbs...
If you need that much trailer to haul your tractor then your probably overloading the truck. Also, you should find the weight of the trailer since a trailer like that is probably over 2,000lbs empty leaving you with little left of that towing capacity for the load.
Deck-over's are nice since you get the extra width and no fenders to worry about but they also tend to be 12-20" higher than traditional trailers making your load top heavy and more apt to sway, plus harder to load since the ramps will be either steeper or longer.
IMO, I think that's too much trailer for a 1/2-ton truck, it won't tow as easily as a car hauler type and will be heavier.
/ Equipment Trailer Question #4
I agree with others that its too much trailer for your truck. Not sure how that trailer is setup, but most pintle hitch trailers put a lot of tongue weight on the truck. Even on a trailer like that 1000-2000lbs of tongue weight isn't out of the question. Great for a heavy 1-ton or 2-ton truck but not a half ton. I would look for a bigger truck to haul that tractor regardless of the trailer.
Just run some numbers and used an estimated 1000 lbs for JD 522 FEL since I don't know the exact weight. Tractor, loader and loaded rear 16.9-28 tires comes to approximately 7300 lbs. My truck is rated for 10,000 lbs. I don't do a lot of towing and don't plan to with this trailer/tractor/truck combination. I would not expect to travel more than 20 miles one way for 95% of the expected use. I wanted to buy a trailer one time and not have to upgrade later. I do however expect to be replacing my truck periodically and thought that if I had a problem with the tow vehicle that I could address that then. I considered a truck upgrade, but honestly don't tow enough to justify it. I had no problems towing this tractor up some pretty good grades on the 400 mile trip home on a 18' 12K rated car hauler. If this was a ball hitch trailer I wouldn't be concerned. I just have never dealt with the pintle type and have always thought they seemed heavier on the tongue weight.
/ Equipment Trailer Question #6
The pintle hitch can be removed and a ball type hitch weld on in it's place.:D
/ Equipment Trailer Question #7
A few things:
1) Stand up ramps usually have a leg that goes onto the ground to support itself when loading equipment on it. When loading heavy equipment you NEED to support the back of the trailer somehow. I broke my old trailer in half loading a skid steer. I now have removeable stand up ramps and just got a longer trailer to solve the problem you mentioned.
2) You need a long trailer with equipment. Short trailers don't have many places to tie down and especially with an undersized tow vehicle getting proper tongue weight will be very important. I can fudge a bit with my dually and tongue weight - you can't. Make sure it's plenty long to allow you to get chains on it at the proper places. Remember you can't chain across the wheel wheel.
3) I paid $3295 for a 20' lamar 14k gvwr trailer brand new with spare tire and LED lights in the spring. Your $2495 might be worth it, but if the brakes are shot you'll spend every dime of the money you saved and still have an old trailer.
4) I hope you're not towing far with that truck. You'll be playing near 10k lbs.
/ Equipment Trailer Question #8
The trailer looks like it has a couple of supports for the back during loading, though they might be better if they were swing-up (so they don't get whacked off if you go through a sharp dip).
I agree about replacing the pintle with a welded on ball hitch.
BOB
/ Equipment Trailer Question #9
If your trailer is over 10K pounds, your will need a CDL A to transport anything!
And that is way too large a load for and F-150.
Good luck.
I do realize the load is at the limits of the tow vehicle. I do not anticipate more than 100 miles annual towing with this set up. I want to insure that the trailer is capable of handling the load and if down the road see I need a larger truck address it then. This trailer is about 7 hours and 450 miles away. Most everything in this size is around $4500 new locally. Figured 12K as a minimum, but if a 14K used could be had for a deal then consider it. This one worth fooling with or keep looking?
/ Equipment Trailer Question #11
Good luck.
This is a untrue statement.
If you exceed $26,001 GVW then you will need a CDL.
I think you are right on this. I just recently let my Class A CDL license go. My work no longer required it for what I do and that was the only reason I obtained it before.
/ Equipment Trailer Question #13
If your trailer is more than 10K you need a CDL A. I have a CDL B, but can not tow a trailer more than 10K GVW because then I am over weight, no matter the tow vehicle.
Marc
/ Equipment Trailer Question #14
Good luck.
Not always true, depends on what state you're in and whether or not you are being compensated for using it.
That pintle hitch just unbolts and can be replaced with a 2 5/16 ball hitch in about 10 minutes and $40.
/ Equipment Trailer Question #15
Marc
Don't want to get into a match here!
For the last 3 years we have had the state DOT here and they have done seminars reguarding this issue.
GENERAL PROVISIONS FOR COMBINATIONS
A combination registration is required for a towing vehicle when the trailer is registered in excess of 10,000 pounds and the cumulative weight of both vehicles exceeds the registered weight of the tow vehicle.
A truck towing a trailer does not need to be registered in combination or have a registered gross weight sufficient to cover the weight of the truck and the trailer if the trailer is registered for 10,000 pounds or less However, each vehicle must be in compliance with its own registered weight.
If you read the text is states a Combination Registration not a Combination License.
/ Equipment Trailer Question #16
I stand corrected.
Not the last mistake I'll make.
But right now, I'm in the process of buying a trailer to to trnsport my equipment, and I am going to stay under 10K so i will encounter NO issues.
Marc
/ Equipment Trailer Question #17
I stand corrected.
Marc
Except the rest of the DOT regulations like med card and log books.
/ Equipment Trailer Question #18
The 10k thing is completely dependent on the state. Here in SC no special license/no med cards/no log book is needed for a trailer over 10k as long as the entire rig is under 26k. Other states vary, I own property in NC and if it was my legal residence I would need a different drivers license for my truck/trailer:confused2:
As it is now I use it up there a lot but I'm good on my regular ole SC drivers license.
/ Equipment Trailer Question #19
Good luck.
Here we go again. :confused2: Too much misinformation out there.
Chris
/ Equipment Trailer Question #20
Deere5105
I agree with the others this is alot of trailer and tractor for your truck, things to consider are brakes and suspension, I hope you have a trailer brake controller if your going to attempt this. Im not trying to doubt your truck or abilities but I tow alot and know the effects of a trailer the size your looking at with loads on it and I have a 3/4 ton Diesel.
Bottom line is BE CAREFUL!
Mike
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
Case SV280B (A60462)
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
TAG 18in Digging Tooth Bucket Excavator Attachment (A60352)
TAG 18in Digging...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
