A newbie oil change question
   / A newbie oil change question #1
dieselkelly
West Luther, Ontario
arctic cat diesel 700 atv
Hi I hope someone can help.
I have a AC Diesel 700. It needs its first oil change. I've read the manual many times.
It says the engine oil I should use is 15W40. The same kind of oil I would purchase for my car's oil change? Is that right?
Diesels don't use another kind of lubericating engine oil?
I live out in the country and don't really want to take my ATV in for an oil change if I can learn do it myself.
Also, I have the correct oil filter (ordered from the dealer) Do I need a special tool to remove the old filter? Thanks, if I can get through it once I'll be set.
   / A newbie oil change question #2
Welcome.
You need an oil formulated for diesels. Rotella is favored by many here.
If you don't have a filter wrench that will fit your filter, take the filter to an auto parts store and find a wrench that will fit.
Steve
   / A newbie oil change question #3
You need to buy oil that is made for a diesel engine.. The two digit ratings will start with a 'C' - such as CF (older rating), CG, CH, CJ (newer rating) etc.. You will want to look at your owners manual and determine what rating they recommend. Typically the newer ratings are backward compatible. IF if it calls for a CG you could use CJ in it..
A lot of ppl use and love Rotella 15w40, it readily available and cost is reasonable - you can get it at walmart, autozone, advance auto - they have 3 versions - dino, synthetic, and a dino/synthetic blend -
good luck
b
Many thanks to you both. Since moving to our farm, my sister and I, we have received more help from members of this site than we could have hoped for. ~ I'd like to learn everything about my ATV and it's maintenance. I also have a new swisher mower with a beautiful Briggs and Stratton gasoline engine.
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
2020 DRAGON ESP...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
