Oversize valves?
/ Oversize valves? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
More posts on my adding remotes idea:
My tractor hydraulics are speced at 7.8gpm. I have a loader and rear PB plumbed in running a backhoe. The PB connectors and backhoe lines are 1/2", the loader plumbing is smaller - probably 3/8"(?). The loader taps into the tractor's hydraulic block and PB comes off of the loader. I plan to use the existing PB runs and make a plug-in dual remote for running snowblower chute controls.
Will a 2-spool 8gpm valve be adequate, or should I go bigger (like to 10gpm)? IOW, are there any resistance issues that has to be considered when more valves are added? How many valves/spools can be put in series before they need to be oversized?
Thx - JayC
/ Oversize valves? #2
If you have 7.2 GPM, and the valve is rated for 8 then you are technically good-to-go. There is no limit to the number of valves in the system as long as they are plumbed properly.
/ Oversize valves? #3
VERY GOOD question!! Seems like you have your hydraulic "nerves" plumbed right...:thumbsup:
This is the negative part of Constant Flow, CF, systems (Open Center, OC), the more PB implements we add (in series) , the more flow resistance we create, which results in more heat added to the system. A Constant Pressure, CP, system (Closed Center, CC) will not react that way when we add more implement valves, because we add, which in parallel. A regular CP-CC system uses a variable displacement pump which adds a substantial cost to this system. Now there is a variant of CF-OC, the CF-CC system also, that uses a low cost fixed displacement pump and a dump valve. The implement valves need to be connected to dump valve, via a signal line or load sensing sensing line, but can be added unlimited in parallel. We can call it "poor mans CC system", and it has gained a lot of popularity on the hydraulic marketplace.
In the 60's, some tractors had a manual valve to dump (by pass the CV) flow to tank, that reduced a lot of heat when road travelling....
Most of the heat in a CF-OC system is created in two different ways..
#1 Road travelling on high rpm's=high flow (implement valves in neutral)
#2 Throttling or feathering implements (diverting) at high pressure and consequently high rpm's=high flow
Constant high rpm is a great way to call for heat problems, so when running implements, use a variable engine speed on demand of flow....
Every time we make a design change in a CF-OC system, we get a change in how system manages HEAT. These CF-OC system are basically not designed to carry a lot of extra implement valves. A tractor that comes standard and "clean", are not designed to carry more than one added valve for a FEL. The system is designed for a certain flow, valve resistance and cooling capacity. If we add several valves, we create more heat and we will get problems to control heat.
THATS why I think your question is SO good!!
It is easy to make a "science" of your question, but harder to give an adequate SIMPLE answer.... especially when input data is lacking necessary details....
This is a very typical way to describe hydraulic capacity, but it actually don't tell you much....Is this pump flow, valve rating or what??? at what rpm's??
In order to control heat (heat status quo), YES, it is good if next valve is slightly over sized, everything added down stream would need to be over sized in order to control heat. But oversizing a valve to much will negatively affect the operational properties on the valve (proportionality and feathering). So you have to negotiate between heat and operation.
I do not think a 10 GPM valve (slightly over sized) will make a noticeable operational difference for you, neither a 8 GPM valve would make a major difference about the heat.
But it all comes back to what specific conditions you are operating under....constant or intermittent, stationary or a lot of 'wheel' travel....
WORKSAVER 3PT / LOADER BALE SPEAR MOUNT (A64278)
WORKSAVER 3PT /...
SHOP PRESS (A64278)
SHOP PRESS (A64278)
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
