Plow conversion ?
/ Plow conversion ? #1
deans
Member
Ontario, Canada
A/C c, Yanmar 155D, Kubota
I have been given a 12 " moldboard plow from a International cub tractor and wonder if I can convert it to fit my Yanmar 3 pt. hitch. I am curious if any one has done this conversion and might share their experience. Hopefully will be increasing my garden size next spring. deans
/ Plow conversion ? #2
Just put you a cross beam on and make sure the right side, standing behind, looking forward, is 3-4 inches lower than the left side. Put on a A-Frame with good back braces and you are good to go. Hope this picture helps. Ken Sweet
/ Plow conversion ? #3
I was just looking at doing this last week. Had a chance to pick up an old AC single bottom frame mount plow. Unfotunately, I passed on it, but still looking.
Question Ken (or anyone else) - I was looking around and see the offset pins - what is the reason for the offset? Some I looked at even had this offset adjustable? Just trying to understand the need for it. Thanks.
Jon Hunter
/ Plow conversion ? #4
Jon Hunter
The offset helps compensate for when the right wheels drop down into the furrow on the second pass. Ken Sweet
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
(1) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(1) 380/85R28...
2012 Volkwagon Passat Sedan (A61569)
2012 Volkwagon...
203201 (A60429)
203201 (A60429)
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2715SSFL (A61567)
2715SSFL (A61567)
