Weight distributing hitch bars question
/ Weight distributing hitch bars question #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I just got my first weight distributing hitch. Not complicated as it looked.:thumbsup: I got a 1200/12000 pound bar set. It is rated from 600-1200 lb tongue weight, which I think is a real good range that should cover most of my needs.
Here is a link to the one I got Pro Series Trunnion Style Weight Distribution Kit with Shank, 1,200 lbs. TW / 12,000 lbs. GTW Pro Series Weight Distribution 49587
That covers me right? I dont need a 600 or a 800 lb bar do I? I saw several different weights available, but the way I understand it, I can do 500 hanging on the truck.
/ Weight distributing hitch bars question #2
You're good. You can get less lift from it by putting it on a different link on the chain when hooking it up.
Less lift would be a longer chain length, correct?
/ Weight distributing hitch bars question #4
That would be correct, but my WD set recommends that the bars remain parallel with the bottom of the trailer tongue frame.
10-4. I'll keep it close.
Bobcat S740 (A57148)
2025 Pabreak 80in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2002 POLAR TANK (A60736)
2002 POLAR TANK...
4021 (A59228)
4021 (A59228)
2019 John Deere 344L Articulated Wheel Loader (A60352)
2019 John Deere...
2016 Globe Trailer GTDD30236 75yd. T/A End Dump Truck (A61568)
2016 Globe Trailer...
