Frozen turnbuckles - L4200
/ Frozen turnbuckles - L4200 #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I tried to adjust the split brakes on my Kubota L4200 and found the adjustment turnbuckles seized. I removed the assemblys, soaked the threads with PB blaster, heated the turnbuckle with a torch, but all efforts failed to free the threads. The primary problem is that the assembly can only be secured at the ends of the bars, so there is anywhere from 6" to a foot of bar between the wrenches, so the bar was twisting before the threads could break free. I gave up and planned to replace the parts, but the two of them will cost ~$125 to replace, so I'd like to give it one more shot. Any suggestions on how to free these things up?
Thanks - JayC
/ Frozen turnbuckles - L4200 #2
Assuming the locknut's are free Some gentle taps with a hammer may help. Use pipe wrenches to get a short grip and try turning in both directions. :D
Tried it all. Locknuts are free. Did beat on them with a hammer with no effect. Pipe wrenches couldn't grab the skinny bars.
I'm wondering if dropping the whole assy into a tub of Kroil or some similar kind of super-penetrating oil for a few days would do it. 'Course, finding a suitable container to fill up is the hard part, not to mention procuring that amount of penetrant.
JayC
/ Frozen turnbuckles - L4200 #4
JayC
Try the hammer thing again laying the long hex part on an anvil or vise anvil and hammer along the length back and forth a few times on something like this it has never failed.
/ Frozen turnbuckles - L4200 #5
How much did you heat it? You should do cherry red to make some impression, usually plumbers torch is not enough.
Soak it with PB Blaster or there was this Chrysler made Mopar rust penetrant
(# 04318039ab) that works miracles.
/ Frozen turnbuckles - L4200 #6
I'm with dex. as long as the ID and OD are not galled or cold welded, the beating on it with a hammer on an anvil virtually HAS to work. what you are doing is deforming the overall OD of the metal.. same principle as sizieng a soft metal ring.. ie.. slip the ring onto a mandrel, and hamer on it.. this makes it thinner.. which makes it's ID and OD bigger.
the inner threaded rod is the mandrel in this case..
soundguy
/ Frozen turnbuckles - L4200 #7
When beating on them with a hammer do you use another heavier hammer as a backup?:)
Try smaller "Steel" pipe wrenches with a cheater bar?:)
/ Frozen turnbuckles - L4200 #8
First of all, quit expecting ANY penetrant to instantly free up anything rusted up! It isn't going to happen. Just keep shooting enough on it everyday to keep it wet and give it time to work. Maybe a week or two even.Then have a go at them! Your brakes haven't been adjusted for quite some time now (obviously, since the adjusters are rusted solid) so what's the rush? :)
/ Frozen turnbuckles - L4200 #9
Yeah. Use PB Blaster or similar for a longer time. I have done as much as a week and then it came apart. If it didn't then the BFH never failed me. I took off nuts that I could not even distinguish from the bolt and the old hammer talked sense into them.
/ Frozen turnbuckles - L4200 #10
Take them off and put them in a vise. Keep soaking with PB Blaster, heat with a torch, work the adjuster or the rods back and forth until they loosen up. Do all of these, or any combination. Hopefully they won't gall. But, I have loosened many this way over the years.
Brian
/ Frozen turnbuckles - L4200 #11
Guys on the old car sites I frequent say that a 50-50 mix of acetone and transmission fluid is the best. The acetone carries the fluid lubricant
through the rust and then evaporates leaving the lubricant. Some say to heat the part and apply candle wax to the threads, the heat draws the wax in.
/ Frozen turnbuckles - L4200 #12
JayC
I've had good results soaking parts in kerosene for a few days. Heating oil would probably work too.
Well, I just did a fluid change on my tractor this past weekend, so I DO have 14 gallons of transmission fluid and engine oil sitting in the back of my truck...
Dang - I knew I should've kept those assys out of the tractor instead of putting it back together before I came home (tractor is at my camp). Oh well - looks like I'm tearing it apart again this weekend...
JayC
I'm sorry Mace, but with that avatar of yours, I am having trouble taking anything you say seriously...
Oh, the pitfalls of comedy :)
You are correct however, no rush (at least until it gets cold...I hate working on machines in the cold)
JayC
/ Frozen turnbuckles - L4200 #15
in the end.. if they break and don adjust.. see if you can fab them. I can tell you I sure have fabbed clutch and brake actuator rods from clevis ends, and rods and threaded couplers before.. plus a few welding rods..
soundguy
/ Frozen turnbuckles - L4200 #17
Break em and sailboat fittings should have something that fits.:thumbsup:
/ Frozen turnbuckles - L4200 #18
or this one!
soundguy
/ Frozen turnbuckles - L4200 #19
soundguy
Yes, there is a huge supply of components for hotrods since they always route the clutch linkage around in impossible ways.
Done it for my CJ7 recently, but I used steering linkage from a lawn tractor for years.
soundguy
Once I gave up on loosening the turnbuckles, I was going to cut n' weld them to force the adjustment. I figured I'd never have to adjust them again anyway. Once I took measurements, however, I found that I had to take out roughly two threads to drop the inch of extra travel. What with having to match the two sides, I didn't feel confident that I could do the work with that kind of precision. OTOH, if I decide that I have nothing to lose...
As the infamous KennyV said, "I know for $110 I would keep at it until they came apart or were in liquid form".
Reverend.
JayC
