Log Splitter?
/ Log Splitter? #1
branman1971
Texas
Yanmar YM1700
Has anyone seen a log splitter hooked up to a Yanmar tractor via hydraulics or PTO? I haven't found one but was curious. It is an implement that I would definitely use.
/ Log Splitter? #2
A log splitter will work with anything that can supply hydraulics. The power and speed of operation will depend on the tractor output in GPM's and pressure.
/ Log Splitter?
I dont think my YM1700 has fittings for the hydraulics, so do you know of a way to install the fittings needed to pump a splitter?
/ Log Splitter? #4
You will probably have to read your manual, and see if you want to run a splitter, based on the pressure and GPM's. Do you have a FEL on the tractor?
/ Log Splitter? #5
Personally I never like the idea of working around a tractor while its running, things could happen! while using the tractors Hydraulics is the safest way of using one, (No drive shaft getting in the way) there are also PTO driven splitters,the tractors PTO drive the wood splitter hydra pump, although these do have drive shafts..... again my own preference would be to simply get a tow behind type splitter, ;) Plus you can rent this kind of splitter out to pay for itself:thumbsup:
/ Log Splitter? #6
Pto driven pump/splitter would be the best way and cleaner overall imo I doubt the tractor hydraulics are even close to enough power but could be wrong.
My gas powered splitter has a 2 speed pump and it gets a work out that's a nice feature on a splitter another reason the tractor pump is probably not ideal.
Anyway your Yanmar may have a 4 speed pto and you can idle the engine most likely and spin the pto at whatever speed you want, thats how I run my 3pt pto driven pump backhoe fwtw.
/ Log Splitter? #7
I love my 3 point hydraulic log splitter, 'specially for spruce rounds I can't lift. Pictures show how I spent last Saturday.
Mf
/ Log Splitter?
Hey Mudfarmer, I sure wouldn't mind spending a saturday doing that.
/ Log Splitter? #9
I used the tractor hydraulics on my 1958 JD 520 for my splitter. Not fast, but it worked fine, I try not to get in a hurry anyway! :D Now that I've sold the 520, I need to re-do the splitter for my 2004- JD 790. Thinking of making it free-standing at the right side of the tractor for access to the joy stick. ~~ grnspot110
/ Log Splitter? #10
Mf
What it the make, and model of your three point, PTO log splitter?
/ Log Splitter? #12
3pt log splitters may not have all the bells and whistles of standalones, like 2 speed pumps, but they are sturdy maintenance-free machines that can go through a lot of work year after year. Their reputation for being slow is meaningless, the men have always slowed my splitting, not the machine.
/ Log Splitter? #13
A picture would be better but:
About 10yrs. ago I built a vertical log splitter/wood rack that mounts to a 3pt hitch on the tractor. The splitter runs off the tractors hydraulics and can split wood either mounted to the tractor or standalone. Recently, I just pulled up to the splitter, attached the hydraulic quick connects and went to splitting.
Get the idea? So I can take the tractor to a fallen tree. I cut, split, and stack the wood on the wood rack. Then drive the tractor (when rack/splitter is on the 3pt) to my deck where I transfer the wood for use. Best setup I could come up with and it really works great.:thumbsup:
/ Log Splitter? #14
I had the same issue, i wanted a log splitter but my yanmar doenst have and hydraulic ports. So i got this sweet machine yeserday. :D:thumbsup: I tried it out today with a chunk of wood and after the first split, i am ready to split the other 6 cord that i have all cut up from both a while back and 5 cord from cutting today. i got a great deal since my splitter came with a free chain saw. I got more hours on that saw already than the splitter. :p In your case, i highly suggest the self propelled unit. A few of the reasons i got mine was...
  1. 1. I dont have hydraulic ports
    2. I want to be able to use it anywhere, even if the tractor is unavailable
    3. If it is self propelled, i wont be putting that many extra hours on my tractor for just splitting firewood, it will be on the splitter itself.
    4. The self propelled can be borrowed out to my neighbors, even without hydraulics on their tractors
    5. i can pull it on the road, try that with a 3 point. :confused2::laughing:
/ Log Splitter?
i got a great deal since my splitter came with a free chain saw. I got more hours on that saw already than the splitter. :[/LIST]
You got a free chainsaw with it? A Husky it looks like...Man thats a deal!
/ Log Splitter? #16
I got a screw in auger that goes on my post hole digger. Screws right into whole logs which I lift with my 3pt or the end of larger logs, it splits the log then I buck off firewood length pieces til I get to the auger, roll the log a quarter turn and do it again. It makes firewood a pleasure.
/ Log Splitter? #17
Actually, its a Husqvarna. :D:D The free chain saw deal was hard to beat. :thumbsup:
/ Log Splitter? #18
3720, Your post from yesterday makes good points with the exception of point #4. Having equipment that can be borrowed by friends/neighbors might be reason not to have a stand alone splitter. Sure, the occasional use by the neighbor is fine and if they also believe in lending out equipment is a workable arrangement.
I just find that borrowing out things doesn't work as well as it should. Of course one could just say no and in that case a stand alone splitter is a good idea. I have a three point splitter and am planning on converting it to a stand alone this winter after all the wood is split and I bored and looking for a project. I just don't plan on telling my neighbors and hopefully they won't see me splitting.
/ Log Splitter? #19
i am also looking at splitters but am going to get a tractor mounted one as i can then split on site and load bucket up and then return it to the shed with minimal fuss.
/ Log Splitter? #20
beachcombed half a dozen logs today, here is that splitter working on one. U can see where I have bucked off split pieces. If I would do it next to the wood pile, would only have to handle it once to stack but I prefer to keep the mess on the beach and bring it to the pile with the loader so the sawdust goes out with the tide. Already had the post hole digger so just traded the guy who makes the splitter some crab and 50 bucks for it.
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2012 DRAGON 150...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
PORTA POTTY (A68842)
2025 60in Hydraulic Forks and Frame Skid Steer Attachment (A66734)
2025 60in...
2016 Jeep Compass SUV (A66738)
2016 Jeep Compass...
2025 28in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 28in Forks...
