PTO Speed?
/ PTO Speed? #1
Steve23240
France
Kubota L1500
I am a complete newcomer to tractors and to this forum. I am a great fan of fora such as this as there are always kind people willing to share their expertise!
I have recently bought a Kubota L1500 (15HP) and a SICMA 95cm flail mower. I am a tad confused about the speed at which the mower should be used; on the PTO housing on the mower itself is a little notice that says 540 rpm, however literature on the SICMA website suggests 2040 rpm. Having cut a little bit of the orchard 540 rpm feels a little slow but I'm afraid to run it at 2040 rpm as it sounds rather too fast. Your advice would be very welcome.
many thanks, Steve
/ PTO Speed? #2
many thanks, Steve
It sounds like the mower needs to be ran at 540 PTO rpm NOT 540 tractor RPM (if the tractor will even go that low)
Most tractors have a standard 540 PTO and a few nave a 1000rpm PTO. But the splines are usually different.
To obtain 540 PTO rpm your tractor needs to be ran somewhere arond 2500RPM. (It should have a mark on your tach that references 540 PTO)
The 2040 is probabally refering to the rpm in which the mower actually runs if given 540 rpm @ the PTO. which would give the mower just under a 4:1 box.
I dont know a lot about flail mowers so this is just a guess. I'm sure others will be along to chime in.
/ PTO Speed? #3
I could be wrong, but I think it is likely that the SICMA documentation probably refers to the flail rpm, not the PTO rpm. The drum or cylinder on the mower probably turns at 2040 rpm when the PTO is running at 540 rpm.
There is another thread on here discussing PTO speeds for your tractor and the following information is for another model which is similar to yours.
PTO 1 requires 2430 engine RPM for 540 PTO RPM. PTO 2 requires 1876 RPM for 540 PTO RPM. At the engine speed you specified for PTO 3, the gearbox was turning about 950 RPM. The correct engine speed for 540 PTO RPMs in PTO 3 is 1300, which puts too much strain on the engine.
http://www.tractorbynet.com/forums/grey-market-tractors/58350-kubota-l1500-l175-power-take.html
You will probably be happier running the engine at a higher rpm in PTO 1 to maintain the PTO 540 rpms when using this mower.
/ PTO Speed?
Thank you both, that is very helpful and makes sense to me. :)
/ PTO Speed?
Another question, if I may? Does the high/low ratio affect both PTO and gearbox or does the PTO turn at the same speed regardless of whether its in high or low ratio?
/ PTO Speed? #6
A lower engine speed puts more loading on the tractor which translates to bad for your tractor.
If you have the No.6 spline on your PTO stub shaft you need to run the tractor at the engine speed required for the 540 R.P.M. Power Take off speed all the time to maintain maximum power delivery to the mower gearbox and flail motor rotor.
/ PTO Speed? #7
I have a finish mower, by Sicma.
My little Kubota tractor needs to spin at 2900 RPM to achieve 540 at the rear PTO. I am inclined to believe your L series would be around 2500 RPM on the tractor, but look for an index on your tachometer of some kind.
Yes, the gearbox on the mower will indeed spin at over 2300 rpm due to its own gearing.
Hi/Lo has no effect on PTO
/ PTO Speed? #8
The PTO RPM is only changed by the engine RPM regardless of the traveling speed of the tractor. Hi/Low only changes the wheel RPM it has no effect on the PTO.
/ PTO Speed?
Brilliant - thank you very much!
/ PTO Speed? #10
Thats why i like my MF 1800 to 2000 RPMs and im at my 540 mark. saving the fuel.:)
/ PTO Speed? #11
Umm.....Aside from the fact that you like your MF, and we're all happy you do, it contributes little to the OP's questions about his L series.
The underlying assumption is that low revs equals good, while higher revs equals bad. Fact is that some engines, like the Kubotas, are designed to rev higher. Doesn't automatically follow they will use more fuel in doing so.
Honda 4 cyl engines, like the one in my wife's car, are notoriously high spinners, merely starting to breathe well at almost 4000 rpm and has a red line at 6500. Nature of the little beastie.
It's great on gas, and known for running 300,000 miles, virtually trouble free. I once had an unsophisticated, older designed 4 banger that would have puked at 4500 rpm. The Honda is of much higher tolerance, design and balance. Have you heard an Indy car or Formula 1 car rev?
Point being, it is meaningless. These are design features. Your Iseki (I assume) is designed one way and a Kubota another. Neither should be viewed as inherently superior to the other, on RPM face value alone.
/ PTO Speed? #12
No actully its a perkins. Didnt say the MF was better than the Bota just showing diff in the rpms between the tractors and yes MF is know for there fuel efficiency.
/ PTO Speed? #13
I'm not sure what a "flail" mower is but I was told to use PTO speed 1 (one) when using any type of a mower with my L1500. The L1500 has four PTO speeds and I think the faster speeds are only used non-mowing attachments. They use the PTO for different things in Japan and the L1500 was designed for the Japanese domestic market.
Here's a photo of my L1500, "Archie" and my German Shepherd Dog, "Go-Go".
2011 Mini Cooper Countryman (A64557)
2011 Mini Cooper...
2003 CATERPILLAR 252 SKID STEER (A65053)
2003 CATERPILLAR...
Kubota SVL75-2 High Flow Compact Track Loader Skid Steer (A64553)
Kubota SVL75-2...
2016 JOHN DEER 5075M TRACTOR AND BUSH HOG (A66091)
2016 JOHN DEER...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
1996 Aspen FP601 Single Pump T/A Fracking Pump Trailer (A64194)
1996 Aspen FP601...
