Mig regulator question
/ Mig regulator question #1
amitysanimal
Carmel, ME
Kubota B7100
Any chance you can use an acetylene regulator on an Argon tank?
/ Mig regulator question #3
Calibrated differently too.
I didn't think I would be that lucky. Thank You for the replies.
/ Mig regulator question #5
If you check ebay, there are a lot of regulators there. We sell them as well. They are good units, but are in lpm, not CFH as some desire. They are a good bit less than a SMITH, of which I own one and a prestolite. They work just as good as either of those two.
/ Mig regulator question #6
Check with your local welding shop. You might get lucky.
/ Mig regulator question #8
You could probably violate all reasoning and take out the acetylene nut and nipple ( CGA 510 ) and buy an inert Nut and nipple ( CGA 580 ) They take the Same Nipple which is a Western Enterprise or Superior # 15-3. The nut is different and both use 1/4 pipe threads..Set it at 2 PSI and it would work. Is it the correct way? Not at all. Will it work ? Yes. You can not convert PSI to CFH so turn it down until you get porassity in your weld... Then turn it back up until you dont. Then leave it alone. ( Should you do it? no. Would it work? Certainly..)
2022 Kubota SVL97-2 Compact Track Loader Skid Steer (A64553)
2022 Kubota...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2022 EZ-GO ELITE...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 Chevrolet...
121A (A63745)
121A (A63745)
