dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,779
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
...I was surprised how close the hoe came in. I could take off the bottom corner of the PTO shield and the hoe's lower steps and come in another 1-2 inches. But then the stabilizers would 1/2" or less from touching the tires. Thats probably too close, yes?
I tried to keep my closest clearances to the tires at no less than 3/4".
One inch is better. Remember, you may buy new tires at some point,
and you should allow for more tread or manufacturer variation. I get some
slight flex on the outriggers, too. My hoe is very forceful.
I trimmed my lower hoe steps in half on my Kioti, and eliminated them
completely on my 4300. I tossed the PTO shield....what a PITA that is.
If either of those is your limiting factor, customize it.
What do you think of adding a cross brace at the front of the frame that gets screwed to the bottom of the tunnel? There are two tapped holes there too. My initial concern is that it will be near impossible to remove this thing but my major concern is weight distribution.
A cross brace at the furthest point forward does not do much, since that
is where the forces are smallest. Also, since there are bolted connections
on both sides, it will have to be fabbed very exactly for width. Doable,
can't hurt, but more work. If you want to add more "rungs" to your
"ladder", add them in the middle. Your steel looks VERY thick there, so I
am not worried about twisting.
