Twine around the front hubs
   / Twine around the front hubs #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
Just got a mfwd JD6415. There is some baler twine wrapped around the front hubs.
I tried to unwrap/pull it off and it just breaks. I want to get it out out before it takes out the front hub seals.
I am worried if I disassemble and disturb the seals they may start to leak anyway.
So far the seals are not leaking
   / Twine around the front hubs #2
Can't you cut it and then get it off one wrap at a time?
   / Twine around the front hubs #3
You might try a dental pick tool?
I have used those tools to get into tough places.
   / Twine around the front hubs #4
If the seals are not leaking now, removing the twine completely gives a better-than-even chance of making the seals leak immediately. Trim off any excess twine that can be easily removed, then leave the rest alone. And have whoever feeds hay pick up after themselves.
   / Twine around the front hubs #5
I agree with Ric. let sleeping seals alone.
Steve
Just bought the tractor and it was delivered that way:mad:. No chance of picking up any more twine.
Sounds like I should just cut off what is hanging out and not disturb the seals.
   / Twine around the front hubs #7
Be sure to check the oil in the hubs. The oil could have already leaked out. If they are full and not leaking, I agree, just cut off the excess and leave them alone.
   / Twine around the front hubs #8
And if they do start leaking, I recommend adding about 20 more turns of twine wrapped very tightly around each hub!! :D
I plan to check all the fluids- Good call!
I did remove all the twine that was hanging out of the hub so it could not be pulled in.
   / Twine around the front hubs #10
If it were mine, it would bother me too much to leave it there. I would remove it, and if the seals leak change them out.
Just can't see that twine protecting a good seal, nor holding oil back if the seal isn't good. :confused3:
But not my call. :)
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Bomag BW120AD-4 Double Drum Roller (A49461)
Bomag BW120AD-4...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
