Twine around the front hubs
   / Twine around the front hubs #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
Just got a mfwd JD6415. There is some baler twine wrapped around the front hubs.
I tried to unwrap/pull it off and it just breaks. I want to get it out out before it takes out the front hub seals.
I am worried if I disassemble and disturb the seals they may start to leak anyway.
So far the seals are not leaking
   / Twine around the front hubs #2
Can't you cut it and then get it off one wrap at a time?
   / Twine around the front hubs #3
You might try a dental pick tool?
I have used those tools to get into tough places.
   / Twine around the front hubs #4
If the seals are not leaking now, removing the twine completely gives a better-than-even chance of making the seals leak immediately. Trim off any excess twine that can be easily removed, then leave the rest alone. And have whoever feeds hay pick up after themselves.
   / Twine around the front hubs #5
I agree with Ric. let sleeping seals alone.
Steve
Just bought the tractor and it was delivered that way:mad:. No chance of picking up any more twine.
Sounds like I should just cut off what is hanging out and not disturb the seals.
   / Twine around the front hubs #7
Be sure to check the oil in the hubs. The oil could have already leaked out. If they are full and not leaking, I agree, just cut off the excess and leave them alone.
   / Twine around the front hubs #8
And if they do start leaking, I recommend adding about 20 more turns of twine wrapped very tightly around each hub!! :D
I plan to check all the fluids- Good call!
I did remove all the twine that was hanging out of the hub so it could not be pulled in.
   / Twine around the front hubs #10
If it were mine, it would bother me too much to leave it there. I would remove it, and if the seals leak change them out.
Just can't see that twine protecting a good seal, nor holding oil back if the seal isn't good. :confused3:
But not my call. :)
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
