Tiller Actual tiller cutting width question....please
/ Actual tiller cutting width question....please #1
yooper1
U. P. of Michigan
New Holland T1510
Hello there tractor guys
I just picked up a 2010 New Holland T1510 tractor (30 HP) w/FEL
It will be delivered Tuesday or Wednesday
I need to also get a tiller. (Basically the only reason for buying the tractor)
I searched the forums and understand it is best to get one as wide or wider than the tire tracks...no problem.
The sheet on the tractor says it is 62 inches wide with 25 HP at the PTO.
(are the specs exact on them brochures...or should I wait and actually measure the tire width from outside to outside?)
Does anyone know if the KKII 60 incher actually cuts 60 inches (which is short I know) or is it only 56 or 58 inches...or will the 2 inches even matter?
I looked at the 72 inc KKII but that requires more pto HP than I would have
The 48" one seems to say the max tractor HP is 25...so would my T1510 be too much for that?
I would be ok with the 48 incher if tire tracks are indeed a big problem (you know, the offset feature)
Thanks in advance guys
I must add:
I know I have been away for a couple of years , and my post count shrunk.
I could'a swore I had more than 1 post before this here one
I am not a drive by poster....honest
/ Actual tiller cutting width question....please #3
Check and see if the KK has any offset. Some tillers have some offset built in. My 62" wide JD 660 is offset and takes out my 72" width tires with ease. Really all you need is for it to take out ONE tire. You can make it work that way but both would be better. If the KK has no offset I think it would take out your tracks pretty easy. They do till wider than they are listed by about 1-2 inches on either side depending on soil conditions.
If your getting it to till lots of ground you might ought to consider stepping up in quality. KK tillers have a good reputation but if your tilling lots of ground for many years your might want to think about something more "commerical" in nature.
Thank you for the reply and info
I just want it for my meager plot....about 50 by 80 or so...and maybe 1 or 2 others like that in town
So...that is good if they cut a bit wider than they are rated at..
thanks again
/ Actual tiller cutting width question....please #5
I think you could go to a 72" with 30 HP. We run a 60" Kubota tiller behind a Kubota B7500 which has 21 Engine and 17 PTO HP.
That tractor seems to run it just fine.
Aaron Z
/ Actual tiller cutting width question....please #6
When I had a 2ohp at the shaft I had no problem with a 6'. I guess it would depend more on soil if you could or not.
Thanks for the replies
The soil at my place has been tilled 2 or 3 years in a row, but has sat 1 year untilled, so it should still be workable.
Maybe I should rent a 6 foot tiller first and see if the tractor handles it.
Thanks again for any and all advice
/ Actual tiller cutting width question....please #8
Does your tractor have a creeper gear? If you have one or a tractor with a really slow 1st gear it will help. Renting a tiller or borrowing one sounds like an excellent idea to see if you tractor will handle it. You might want to check with the dealer where you are buying the tractor as to what they reccommend. They might give you a "deal" on one since you are buying the tractor, and they would deliver it with the tractor.
Creeper gear...no
but it is a hydro transmission so I should be able to go slow enough
The dealer "says" they only carry LandPride and the only have 1 in stock....
they rented it out twice and they still want $2400 for it ($2400 for something used?! FUNNY!!!)
I honestly forgot to ask the size then.
But he did say he would rent it to me.
Maybe I will do that first...rent that one here next month...after I douse the plot with roundup and let it breathe.
/ Actual tiller cutting width question....please #10
No reason for Roundup. Your tiller will kill EVERYTHING it runs over. Tillers serve two functions. One to prepare a seedbed by making it plantable and the other is killing weeds/grass like you can't belive. Now you'll need to mow it or the grass and vines will wrap around the rotar. But just save your money on the roundup. Let the tiller get you a total kill.
/ Actual tiller cutting width question....please #11
Tilling will not necessarily kill all of the grass in an area. If you have any clumps of grass left on top, they will regrow.
Now, if you are able to get all of it tilled under below where it can get light, that will kill it.
Aaron Z
/ Actual tiller cutting width question....please #12
I haven't had to use Roundup yet. Till it once and let it lay for a week or two until all the partially exposed grass start growing again and the dormant seeds you just exposed germinate. Till it again and very little will sprout for a least a few weeks. This works for my soil in my climate - your results may vary.
To the OP:
I'm running a 5' KKII on a 32HP L3240 that is 62" across the outside of my rears, just like yours. The tiller is built offset about 3" to the right (viewed from aft), so it covers the right rear tire track and about half of the left with it mounted staight on the tractor. 5' is a nice match to the HP. There have been only a few occaisions when I wanted a 6 footer but many when I was glad I only had the 5. Ran it yesterday in 3rd gear bustin' sod for a new garden plot out in our field. She ran like a champ.
-Jim
<snip>
To the OP:
I'm running a 5' KKII on a 32HP L3240 that is 62" across the outside of my rears, just like yours. The tiller is built offset about 3" to the right (viewed from aft), so it covers the right rear tire track and about half of the left with it mounted staight on the tractor. 5' is a nice match to the HP. </snip>
-Jim
Thank you, thank you for an answer to the actual question / problem / worry
So I guess I will go with a 5 foot KKII
Nice to know it is offset a few inches and that it will cover at least 1 tire
Thank you again
/ Actual tiller cutting width question....please #14
You're welcome - just double check that the KKII 5' is still offset - mine's about 3 years old. The offset is something that I never noticed until last year when I was hitching it up. When I got the tiller parallel to the rear axle the durn thing wasn't centered on the tires. KK advertises that their 4' is offset, but I don't remember so much as a word about the 5' being offset.
Anyway - check before you pays your money.
-Jim
/ Actual tiller cutting width question....please #15
Get a tiller that covers both tracks if at all possible its just a better way to till not having any compaction anywhere. The garden will look better and you will be happier and when you hire out its really going to pay off. jmho
There-in lies the problem / question
My tractor is 62" wide (supposedly)
no one can say for sure if my tractor has enough PTO HP for a 72 inch tiller
(Even the MFG's sites suggest a higher HP than I have at the PTO)
A 60 inch tiller will work with my PTO HP plus it may be offset a bit and will cover 1 tire completely and most of the other.
the final pass will / should have no compacted earth under it if done correctly
/ Actual tiller cutting width question....please #17
You are probably ok with a 60" tiller being as how there will be spill over anyway and if one wheel is completely covered I think you are close enough for it not to matter now that I think about it. hth
btw I have a 72" KK2 and love the heck out of it if that helps as a brand reference!!!
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
2022 PETERBILT 579 DUMP TRUCK (A62130)
2022 PETERBILT 579...
Case 586H 4wd Off road forklift (A63118)
Case 586H 4wd Off...
2019 Kenworth T270 Flat Bed Dump Truck, VIN # 2NKHHM6X3KM358768 (A61165)
2019 Kenworth T270...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
