Should I look for the woods 4pt for grand L's? something like $1K the last time I checked. I already have a woods loader.
Should I attempt to modify the ladder style mount I have out behind the barn? The front just needs a place to mount the cross pin and I think that would be easy. I suspect the rear will be very low due to the design of this tractor and my industrial tires. The ford used bolts/pins from the axle housing to carry the rear of the subframe.
I like the Woods 4-pt subframe for the Lxx30 tractors. These days, you
will likely pay over $1K for it, and it could take a while to receive it.
Since you have the other subframe already, modifying it could be a simple
and straight-forward job, even if it is not ideal. No doubt it would be
better than your 3PH.
If you make one from scratch, or modify the one you have, you should
be able to mount the hoe closer to the tractor than even the Woods
4-pt subframe does.
Note the older 750 hoes from Woods have their hyd reliefs set at no
more than 2000 psi, and your tractor puts out a healthy 2500psi (at 8+
GPM). This can be limiting to your FEL if you keep the hoe mounted,
unless you use a hyd work port for power (and disconnect the hoe hyds
when not in use).
As noted, the raw forces you can apply with your hoe at low hyd flow
rates get higher when higher flows are used, due to the momentum
of the faster moving boom, dipper, and heavy loads in the bkt. And,
since pins are not snug, you will increase the hammering action on
the pins and holes at higher flow rates.
