Cutting on my BRAND NEW Tractor
   / Cutting on my BRAND NEW Tractor #1
MBDiagMan
Gold Member
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
I got my brand new, bright, shiny JD 5045D yesterday. It sure is "purty." I know that it won't look that way for long, but I want to keep this one indoors. The spot I have for it involves a standard height, probably a little less than 7 feet, overhead door.
The ROPS can easily fold over to clear the door, but the exhaust stack is too tall. The stack has a turn out rather than a rain cap. As much as I hate to cut my brand new exhaust stack I think I'm going to cut it with an exhaust cutter so there will be no chips down the stack and then put a rain cap in place.
I've never bought a brand new tractor before, so this is traumatic to start cutting on a brand new machine. I suppose it's worth it to keep it out of the weather.
   / Cutting on my BRAND NEW Tractor #2
Can you remove the pipe where it attaches to the muffler lower down, cut it there and Drop it a few inches, leaving the turn/bend at the top ?
My exhaust pipe is like that, lucky for me, my garage door is 9' high, so no need to cut it.
Thanks for the suggestion. I will look at the bottom and see how it's made. Although a tractor is more about function than form, I don't want to make it look bad, at least while it's brand new.
My alternative is to keep my 64 Ford Galaxie 500 in the shop with a low door and keep the tractor in the "new" shop. The "new" shop is an old hay barn that I converted to a shop when I stopped baling square bales. It has 13 1/2 foot doors. The Galaxie is so long that I'm not sure it will fit in the other shop.
Thanks again,
   / Cutting on my BRAND NEW Tractor #5
I modified a door on a building a few years ago to get a cab tractor inside. Ken Sweet
   / Cutting on my BRAND NEW Tractor #6
I'm also in favor of the chrome stack! :thumbsup:
   / Cutting on my BRAND NEW Tractor #10
There is a factory low exhaust kit. I think it exits in front of the floorboard... saw one on a 5055E. Looked good...
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2022 Kubota Z422-54 Zero Turn Mower (A55315)
2022 Kubota...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
cummins generator (A56857)
cummins generator...
