Cutting on my BRAND NEW Tractor
   / Cutting on my BRAND NEW Tractor #1
MBDiagMan
Gold Member
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
I got my brand new, bright, shiny JD 5045D yesterday. It sure is "purty." I know that it won't look that way for long, but I want to keep this one indoors. The spot I have for it involves a standard height, probably a little less than 7 feet, overhead door.
The ROPS can easily fold over to clear the door, but the exhaust stack is too tall. The stack has a turn out rather than a rain cap. As much as I hate to cut my brand new exhaust stack I think I'm going to cut it with an exhaust cutter so there will be no chips down the stack and then put a rain cap in place.
I've never bought a brand new tractor before, so this is traumatic to start cutting on a brand new machine. I suppose it's worth it to keep it out of the weather.
   / Cutting on my BRAND NEW Tractor #2
Can you remove the pipe where it attaches to the muffler lower down, cut it there and Drop it a few inches, leaving the turn/bend at the top ?
My exhaust pipe is like that, lucky for me, my garage door is 9' high, so no need to cut it.
Thanks for the suggestion. I will look at the bottom and see how it's made. Although a tractor is more about function than form, I don't want to make it look bad, at least while it's brand new.
My alternative is to keep my 64 Ford Galaxie 500 in the shop with a low door and keep the tractor in the "new" shop. The "new" shop is an old hay barn that I converted to a shop when I stopped baling square bales. It has 13 1/2 foot doors. The Galaxie is so long that I'm not sure it will fit in the other shop.
Thanks again,
   / Cutting on my BRAND NEW Tractor #5
I modified a door on a building a few years ago to get a cab tractor inside. Ken Sweet
   / Cutting on my BRAND NEW Tractor #6
I'm also in favor of the chrome stack! :thumbsup:
   / Cutting on my BRAND NEW Tractor #10
There is a factory low exhaust kit. I think it exits in front of the floorboard... saw one on a 5055E. Looked good...
2018 Ford F-350 (A55973)
2018 Ford F-350...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
