Transmission types for JD 40 series.
/ Transmission types for JD 40 series. #11
I was interested in these tractors when they were introduced. IIRC, the 2240 was the first available with either hi-low or reverser tranny both functions were hydraulic operated wet clutchpack. Very nice 50 hp (pto) tractor for the day, "I wanted one!":D
/ Transmission types for JD 40 series. #12
Is the hi-lo a "wet" or hydraulic shift? Or is it a "dry" clutch shift?
Thanks.
AKfish
The tractor has a main dry clutch. The Hi-Lo unit has an internal wet clutch that allows up or down shifting of the Hi-Lo without clutching.
Basicly the Hi-Lo only allows a down shift and then an up shift back for what ever gear you are in. Say you are brush hogging in 4th gear and hit a heavy patch. With HI-Lo you shift to Lo. Almost the same as shifting to 3rd gear, but no stopping or clutching (non syncronized collar shift transmissions). After you get thru the heavy stuff, you shift from Lo back to Hi with the Hi-LO, and are back in 4th gear, no stopping or clutching.
So a Hi-Lo does not change the 8 speed to 16 speeds, it just allows a down shift and up shift back to the gear you are in without clutching.
PTO clutch can be either wet or dry. I have seen both ways.
Sounds like it (hi-lo) would make for a real nice baler and disc mower tractor! :thumbsup:
AKfish
I'm still "waffling" about selling my 110 and going for a cabbed 4520 or 4720. Gettin' more interested in a nice, 2440 or a 2640 with hi-lo and a 146 FEL.
It makes more sense to have two tractors.. instead of 1 cab model. :D
AKfish
/ Transmission types for JD 40 series. #15
For a removable FEL look for a JD175 or JD245
/ Transmission types for JD 40 series. #17
Why's that....?
AKfish
If you want to be able to remove the loader. These models are not permenantly mounted.
If you plan to put the loader on and never take it off, don't bother with these.
/ Transmission types for JD 40 series. #18
AKfish
I think it make the most sense to have both cab models and a canopy tractor with gears just incase you have to argue with someone on TBN popular threads, "Hydro vs. gear and Open station vs. cab.:laughing:
Check out the 820 thread below this one, I posted a pico f my 820 canopy.
Yep... gotta cover ALL sides of the debate!! :D
'Course I've sat in the cab of the 4000 series - and I don't think there's quite enough room for both the TV and my toothbrush - 'cause that's where I'd be living if the JD dealer's tractor-trailer pulled up with 2 new cabbed 4520 and 4720! :eek:
AKfish
/ Transmission types for JD 40 series. #20
I've had a 2240 and currently have a 2440. Both have "regular" sliding gear transmissions. 2 sticks on the transl or "floor", the left one is low, high and reverse, the right one is 1-4. Neither are synchronized, but you can usually double clutch the 1-4 at speed at least 1-2 and 3-4 upshifts. The reverser and hi low are hydraulic and didn't hold up well.
The 2440 is a great tractor, my father bought it used a month after I was born in 79. Its currently got 9800 hrs on it with the original motor, 1 clutch job and 2 pump rebuilds. For years it was the main tractor on the farm, haying, plowing, and chopping corn.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
OXBO PixALL Big Jack Mark III (A60462)
OXBO PixALL Big...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
