wood chipper/ seat safety switch
/ wood chipper/ seat safety switch #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
when a wood chipper is hooked up to the rear PTO, ,how do I keep the tractor from shutting down? as the seat safety switch shuts down the unit?
/ wood chipper/ seat safety switch #2
Try flipping your seat forward then start the engine and engage the PTO.
/ wood chipper/ seat safety switch #3
As I stand up, I grab the seat in the same motion... as I step off the tractor, I tip the seat up and onto the steering wheel....
/ wood chipper/ seat safety switch #4
I might not be that coordinated:D. I get off the tractor, flip the seat up, engage the PTO at/near idle then throttle up to PTO RPM. When finished I reverse the order.
/ wood chipper/ seat safety switch #5
I am sure it is the same on your 7800 but as per my 3400 operator mauual, once off the seat you have like 1 second to flip it forward before it kills the tractor. I do like mentioned above, flip the seat up with one hand while standing up at the same time.
I have never tried starting it with the seat already up, but I suppose that would work also.
this morning I lifted the seat to the steering wheel started the unit let it warm up pushed the clutch with my hand again and engaged the PTO. It seemed to work. Hope there are no safety issues with this method?
/ wood chipper/ seat safety switch #7
There shouldn't be as that is how the manual says to do it. I am sure you have the brakes locked, but on some Kubota models the brakes are kind of weak and you might want to consider chocks if you are on any kind of incline if your model is one of them.
/ wood chipper/ seat safety switch #8
I've pretty much got into the habit of raising the seat up any time I get off the tractor... It's usually in the sun and I hate coming back to a HOT seat... :p Guess I need to get a canopy :)
teg I am just up the road from you. Yesterday a fella on craigslist had a new kubota canopy for sale. He noticed after he installed it it would not fit in his garage his loss someones gain. $250.
/ wood chipper/ seat safety switch #10
:ashamed: I have the same problem... I have two things that would work (golf cart top and one of the very large yellow Cat. tops) I just don't have an inch to spare... need to build a larger barn. :eek: But thanks for the heads up!!!
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
60 Inch Attachment (A64553)
60 Inch Attachment...
2005 Chevrolet Suburban SUV (A64194)
2005 Chevrolet...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2018 CATERPILLAR 303E CR EXCAVATOR (A65053)
2018 CATERPILLAR...
