3-Point Hitch pto cement mixer
/ pto cement mixer #1
slowsailor
kubota bx1850
I just purchased a Kubota BX 1850 to bring to Panama for my farm. Last time I was on a tractor was in the 60's. I would like to mount a pto cement mixer, does any one have experience and/or recommendations. I would appreciate any comments. Thanks!
/ pto cement mixer #2
I have thought about it. The last time I poured concrete (three days ago) I had to use my generator and mixer,
/ pto cement mixer #3
Wish I did have experience with a pto mixer, and will be watching this thread...Welcome to TBN.
Don
/ pto cement mixer #4
I have a 1/3 yard pto mixer that I use occasionally for sidewalk squares or other little projects. I used to buy cement and gravel/sand separately, but now prefer the 80# bags of high strength premixed stuff. Throw a few into the mixer, add water until it looks creamy and take it directly to the site. This mixer has a 1 way cylinder on it and a garage door spring for the return cycle. I use one of my loader circuits for the connection.
Concrete ready to use is VERY heavy. With the front weight bar loaded with JD suitcase weights, my JD 1070's front wheels can come off the ground with a small bump. I've often used the mixer with the loader attached and with stones in the bucket. This means not being able to use the curl circuit because I need it for the mixer dump.
Make-Your-Own concrete is a lot of fun. (and I'm not Italian). I use 2x4s for forms and little of no rebar or metal. Its a good place to get rid of all those crappy tools you hate to use but also hate to throw in a dumpster.
The strength of the concrete I make is far superior to anything I've had to buy ready mixed. Once I was making a driveway extension and started out with my mixer. Well It was gonna take a month to get it done and lifting those 80# bags into the bowl was not fun. I bought the rest. Well, my own recipe stuff has help up crack free. The commercial stuff is cracked from a roofing delivery truck. Oops.
BTW: My dogs really like to walk across fresh cement. They'll never use a sidewalk when its hard, just when its soft. Old Zeke's paw prints will outlast me....
/ pto cement mixer #5
What's your mix recipe - or is it an old family secret?
/ pto cement mixer #6
Besides using the premixed cement and sand from Lowes, Menards or Home Depot, my 'secret' for strong concrete is to minimize working it. Pour it, float it, and leave it alone. Keep the top surface wet using a fine spray hose for 4 - 6 days. Concrete is a chemical reaction, and the heat of formation is damaging to the ultimate strength. The water keeps it cool.
/ pto cement mixer #7
Most of the three-point mixers that I've seen would be too large for a BX1850. This is not only due to the weight, but the working mechanics required to dump. If you don't mind manual mixing, you can use the front end loader then dump where you want.
Mike
/ pto cement mixer #8
We have the new 1/3 yard capacity for $799 + modest shipping. Ken Sweet
/ pto cement mixer #9
I explored this idea a few years ago with the 1/3 yard PTO mixer and my dealer highly advised against it for a BX series. The safety factor outweighed the convenience.
/ pto cement mixer #12
Maybe one that is slightly smaller would be better. I see a 5 cubic ft one (27 cubic feet in cubic yard) that would not be as heavy. Or make sure you don't put more in than what your tractor can handle.
5 cubic ft of concrete can weigh over 600lbs, plus several hundred for the mixer, you can get over 800lbs pretty fast. When it is dumping, the weight moves away from the tractor (before it falls out of the mixer).
Looks like they use hydraulic top link to dump, so you will need remotes or borrow a loader circuit...
Good luck
/ pto cement mixer #13
With a FEL adding front ballast, you don't have to worry about the front coming off the ground. Ken Sweet
/ pto cement mixer #14
For general purpose concrete, 3 shovels of aggregate to 1 shovel of cement. Add just enough water to make the concrete workable. Too much water weakens the concrete. You don't want it so wet it is soupy.
I generally buy aggregate from a local sand and gravel company. Well designed aggregate has a gradation from sand to coarse that doesn't leave air pockets in the cement. In extremity, I have used basalt 3/4 minus with plenty of fines in it, and it made pretty strong concrete. I wouldn't want to try flatwork with the stuff, though. It was pretty rough.
In the old days, we used to just go to the river and shovel up sand and gravel. If you toss a shovel full in a bucket of water and the water gets muddy, it is too dirty to make good concrete. My area is wealthy in rock. In some areas, you have a hard time finding good rock for concrete.
Go to a mason supply for your cement, where they rotate their stock frequently. It may have been sitting around a lumber yard drawing moisture for over a year. Fresh cement has the texture of all purpose flour. If it has hard lumps in it, it has lost part of its strength while it is still in the bag.
I am a big believer in rebar. Hand mixing concrete is a lot of work. I don't want it shifting and cracking, so I put rebar in everything I do. Rebar is numbered by 1/8ths of an inch, so a #3 is 3/8 of an inch, #4 is half inch. #4 in a 12x12 mat is about right for flat work.
/ pto cement mixer #15
I have sold several for the BX 22 series. No problems reported. Ken Sweet
Concrete weighs 3600 lbs. per cubic yard, so your mixer plus concrete would weigh in at around 1600 or 1700 lbs., which approaches the weight of some small tractors. I think someone mentioned putting rocks in the front loader, which would be a real good idea for any small tractor. Anyone can check the specs on their tractor for weight and 3-point capacity. Almost any 3-point would handle the weight, but a small tractor may end up with its wheels in the air. :laughing:
/ pto cement mixer #16
That's the one I have had for many years. My concern is that the BX
is not tall enough for proper dumping.
Lots of TBN posts over the years on the Mixer80.
As for mix design, the strongest concrete will have a high Portland cement
ratio, a low slump, and large aggregate. Mixing my own, I have done lots of
0" slump mud with 1.5" aggregate (with rebar). Super-strong and no cracks.
/ pto cement mixer #17
Does your mixer have the series of holes for the lift arm pins to go in for different lift heights? Ken Sweet
/ pto cement mixer #18
I've mixed a lot of concrete and the "secrets" I use are keeping the concrete wet for as long as possible. Concrete doesn't dry, it sets. If the concrete dries before it chemicaly sets it will never get any harder even if you wet it down after. I've used burlap bags or, for flat surfaces, you can "pond" the surface so a layer of water stay on it. Concrete will continue to gain strenght over time but the first 28 days are when it gets its best strenght.
If I'm using bagged ciment I add a very small portion of, and don't laugh, Mr. Bubble. Pre-mixed concrete already has air entrainement agent mixed in but bagged ciment does not. Minute air bubbles in the concrete are very important if the concrete is subject to freeze/thaw cycles. Mr. Bubble also makes the concrete pour a lot easier as the concrete is much more fluid.
Use as little water as possible. The more water, the weaker the concrete.
Don't overwork the surface or the final product will have a fine layer of concrete dust which will always remain dusty. A dusty surface will also not accept paint as the paint can't adhere to a dusty surface. Lasty, and as was said before, work the concrete as little as possible from mixing to pouring.
/ pto cement mixer #19
These replies on adding too much water remind me of a saying I heard a LONG time ago. If the concrete is too dry, try adding sweat.
/ pto cement mixer #20
I doubt many people here would have a test cone or know how to use one.
For general information, slump is measured with a 12" test cone. You fill the cone with concrete, rod it carefully, then lift the cone shaped form. How far the concrete slumps is the slump. No slump is known as a dry pack. It has enough water to hydrate the cement, and no more. You have to ram it into place, and where you put it it stays. The surface does not have a smooth finish, and looks like sand and gravel. It gets very hard.
Typical flatwork concrete will be delivered with a 4" to 6" slump. That's a compromise between strength and workability. If you stay on it, you can trowel a smooth slab with a 4" slump.
Workability can be improved by adding a pozzolan, like fine fly ash. It makes the concrete pastier without affecting the strength. If you want to try a smooth finish with a 2" slump, buy a bag of pozzolan from the mason supply house and add some to the mix. Air entraining will make concrete more workable too. I liked the Mr. Bubble suggestion, and will try that someday. Sugar will ****** the cure. You can spray vertical forms with sugar water, pour them full, then strip the forms off and do a trowel finish on a vertical surface. Calcium chloride will make concrete set faster. Aluminum powder will make concrete expand because the aluminum generates hydrogen bubbles. Don't use too much. One handful in a 9 yard concrete truck is plenty.
Do not let concrete freeze until it is fully cured or it will turn to punk. A light frost is usually not a problem, because concrete generates internal heat as it cures. A hard freeze will destroy it. Concrete in hot weather is also a bad idea, though you can ask the batch plant to batch with ice to slow the chemical reaction. The best day to pour concrete is 50 degrees and overcast, with a light drizzle that starts right after you finish.
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
