3-Point Hitch pto cement mixer
   / pto cement mixer #1
slowsailor
kubota bx1850
I just purchased a Kubota BX 1850 to bring to Panama for my farm. Last time I was on a tractor was in the 60's. I would like to mount a pto cement mixer, does any one have experience and/or recommendations. I would appreciate any comments. Thanks!
   / pto cement mixer #2
I have thought about it. The last time I poured concrete (three days ago) I had to use my generator and mixer,
   / pto cement mixer #3
Wish I did have experience with a pto mixer, and will be watching this thread...Welcome to TBN.
Don
   / pto cement mixer #4
I have a 1/3 yard pto mixer that I use occasionally for sidewalk squares or other little projects. I used to buy cement and gravel/sand separately, but now prefer the 80# bags of high strength premixed stuff. Throw a few into the mixer, add water until it looks creamy and take it directly to the site. This mixer has a 1 way cylinder on it and a garage door spring for the return cycle. I use one of my loader circuits for the connection.
Concrete ready to use is VERY heavy. With the front weight bar loaded with JD suitcase weights, my JD 1070's front wheels can come off the ground with a small bump. I've often used the mixer with the loader attached and with stones in the bucket. This means not being able to use the curl circuit because I need it for the mixer dump.
Make-Your-Own concrete is a lot of fun. (and I'm not Italian). I use 2x4s for forms and little of no rebar or metal. Its a good place to get rid of all those crappy tools you hate to use but also hate to throw in a dumpster.
The strength of the concrete I make is far superior to anything I've had to buy ready mixed. Once I was making a driveway extension and started out with my mixer. Well It was gonna take a month to get it done and lifting those 80# bags into the bowl was not fun. I bought the rest. Well, my own recipe stuff has help up crack free. The commercial stuff is cracked from a roofing delivery truck. Oops.
BTW: My dogs really like to walk across fresh cement. They'll never use a sidewalk when its hard, just when its soft. Old Zeke's paw prints will outlast me....
   / pto cement mixer #5
What's your mix recipe - or is it an old family secret?
   / pto cement mixer #6
Besides using the premixed cement and sand from Lowes, Menards or Home Depot, my 'secret' for strong concrete is to minimize working it. Pour it, float it, and leave it alone. Keep the top surface wet using a fine spray hose for 4 - 6 days. Concrete is a chemical reaction, and the heat of formation is damaging to the ultimate strength. The water keeps it cool.
   / pto cement mixer #7
Most of the three-point mixers that I've seen would be too large for a BX1850. This is not only due to the weight, but the working mechanics required to dump. If you don't mind manual mixing, you can use the front end loader then dump where you want.
Mike
   / pto cement mixer #8
We have the new 1/3 yard capacity for $799 + modest shipping. Ken Sweet
   / pto cement mixer #9
I explored this idea a few years ago with the 1/3 yard PTO mixer and my dealer highly advised against it for a BX series. The safety factor outweighed the convenience.
   / pto cement mixer #10
I have sold several for the BX 22 series. No problems reported. Ken Sweet
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
