Crushing Cans?
/ Crushing Cans? #1
mjarrels
Elite Member
Virginia
1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
Need ideas on how to crush cans? Wife started a recycle program at the 36 hole golf course next door where she works, about every other day, she brings home a 60 gallon trash bag full of cans (12oz to 24oz). Recycle center, they must be crushed to reduce space. I have cans running out of my ears, one bay in the garage is full and about 12 bags in the driveway with more coming every other day. Tried using the tractor FEL but that didn't work well, tried using a heavy spltting maul on each can, works but it takes forever. Any suggestions without spending big dollars?
mark
/ Crushing Cans? #3
When I used to recycle pop cans, I would lay a bag out in the yard and drive over them with the truck. A couple of times back and forth and most were flat. Then I realized between using gas smashing them, buying trash bags to store them, the gas to drive them in town, the bees that the sweet pop attracted it wasn't worth it for what little money I got from them, and started throwing them away.:confused2:
/ Crushing Cans? #4
Down in the country, I had one like the first of those two mounted on the wall in the shop with a garbage bag below it to catch the cans. It took a long time for us to fill a 30 gallon garbage bag and when I got 2 of them filled, I took them to town and sold them. It worked very well, but might be a bit slow for what Mark needs.
And now, I no longer mess with crushing, saving, and selling cans. We just put them in the recycling bin that Waste Management picks up.
/ Crushing Cans? #5
I tried making a machine with two rotating tires and drop the can in the middle. Might have worked but the tires turned to fast and it fell apart.
I then made a crusher but taking an old table and put a door hinge on it to lever a piece of decking down to crush it , Then had a hole cut in the table to push the can off the side and drop int he bucket worked well.
/ Crushing Cans? #6
Well, either one is better than sitting them on the driveway and stomping them with my size 11W.:laughing:
I just mounted one of the single can models in our garage and it is terrific. I figured Mark might build a hopper feed for the multi-crusher and get this down to a science. With all those tractors, surely he can figure how to use remote hydraulics to make this work. A log splitter could also be rigged to crush cans pretty easily.:thumbsup:
/ Crushing Cans?
Thanks for the idea Jim, but Bird is correct... We are talking about a huge amount of cans. Yesterday, the City Chamber of Commerce had a golf outing, wife will probably show up today with two 60 gallon bags filled full. We are probably in the hundreds of pounds now.
mark
/ Crushing Cans? #9
I built one with a 2" air cylinder, and a lever type control valve. Added quick dump valves and mufflers to the cylinder to speed it up and make it quieter. I average about 45 cans per minute.
The box I keep in the house holds about 80 cans (~$2.00 worth) and I can crush them in jsut under 2 minutes and the air compressor only has to run for 35 sec to catch up. With a 15A motor @ 220 I figured it one time to be under 4cents to catch up.
I'll try to get a vid when I get home or some pics.
/ Crushing Cans? #10
Mark, can't you find a place that will buy them without them being crushed? Of course it's been 20-30 years ago, but my parents lived in Port Aransas in a mobile home/RV park. One year, one of the other men in the park was saving cans for his grandson'e boy scout troup, so Dad was helping him. Of course these old men went fishing every day, drove around the fishing piers, the jetties, along the beach, etc. A lot of people throw empty cans down wherever they were, but there are also lot of trash barrels and a lot of people use them, too. So the men went through the trash barrels, too. They gathered lots of cans and it was so easy down there that after the boy scout program was done, Dad just kept picking up the cans, throwing them in the bed of his pickup, and then put them in garbage bags at the house. And he would periodically take a truck load to sell without them being crushed.
/ Crushing Cans? #11
For fun I followed the sales link at the top of the page and found this in about 3 clicks.
CAN-RAM-ALUMINUM-CAN-CRUSHER-CRUSH-10-CANS-ONCE
Brian
/ Crushing Cans? #12
loader bucket,2x8 wood frame a couple inches wider than the bucket :thumbsup:
/ Crushing Cans? #13
Search for 'can crusher' on youtube, all sorts of ideas! :)
/ Crushing Cans? #14
Don't take them to the recycling center, sell them. I crush mine at home. We put them in a drum and I use a 4x4 to mash them. JC
/ Crushing Cans? #15
If you have a log splitter it probably would not take much to devise a can crushing application...
/ Crushing Cans? #16
Not efficient but...My dad took a piece of 5"x5" 4" thick steel and welded it to a 5 foot steel pole for crushing cans......Was called the Polish Compactor, after our nationality:D.
Good workout anyway.
/ Crushing Cans? #17
To keep our tractors "Justified", how about taking a couple of lenghts of pipe, heavy wall, and add bearings to each end, like a sheet metal roller, except have two and side by side. Add pto power to one, to power them, build a V-box above them to funnel the cans towards the narrow slot between the two rollers. You will probably have to add some sort of catching device to grab the cans and start the cans towards the V, such as rows of weld, or just adding short fingers, like short bolts.
Crushing is usually for convience of storage, and not mandated by the scrap yards, that I have ever seen. Keeping the area crushing and storage area washed down helps with the control of bees and other unwanted criters.
David from jax
A gear reduction motor or pulleys to slow down a typical 1725 rpm motor would probaby be easier than hooking up a tractor pto, but this is a tractor board!!!
/ Crushing Cans? #18
David from jax
I crush them just for my convience. 2 55gal barrels full crushed would be a whole truckload by itself if uncrushed. Given there isn't much money in it, when I go to recycle, I like taking in other things as well, like copper, etc.
But some of the yards around me WONT take them crushed. Too many people putting rocks in them and crushing to add to the weight. Fortunatally where I go, they take them either way.
/ Crushing Cans? #19
my local buyer don't want them crushed.
/ Crushing Cans? #20
David, it seems to me that what you are describing is very close to the old wringer washing machines. With one of those, you could just use the washer tub for a catch bin. The rubber coated rollers should grab the cans and pull them into the wringer.:cool2:
Oh yes. . . use your tractor to move it from place to place.;)
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A67714)
PALLET OF 2CYL GAS...
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
