rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,409
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Not sure offhand what year it is - we bought it new around '03 or '04 I think - it has around 1035 hours on it, it has been worked, but has had all the normal scheduled maintenance, except for two things:
1. engine coolant has never been changed and,
2. the valves have never been adjusted.
Today I was using the backhoe (BH4690B) on the B2910 ..... I finished and just as I was stepping off the backhoe the engine started chugging and sputtering ....
I moved the throttle down from 1800 rpm to the idle position (1200 rpm) and it died out. I was able to restart it and it idled somewhat rougher than normal for a few seconds ...... then I tried to raise the engine rpm and it starting chugging again and died out. No abnormal smoke (it does smoke a little black initially when started for a couple of seconds and when under load and being worked hard)
First thing I checked was the oil - it looked fairly clear/amber in the evening light - which I found a little odd considering there was around 35 or 40 hours on the oil (I changed it at 1000 hours with Rotella T6 Synthetic 5w40) ..... but also there seemed to be some small bubbles on the stick when I pulled it initially .... enough that I stuck and pulled it again - same thing: a few small bubbles on the dipstick. No evidence of water in the oil though.
Next thing I did was pull the air filter - it was surprisingly clean, considering that I've been operating in fairly dusty conditions and hadn't pulled and cleaned it for the last 35 hours. Just a little bit of grass inside the housing and not much dust/dirt at all.
Couple things other things:
This past week I was out working, knocking over trees and digging out stumps ...... at one point I shut the tractor off to take a break. When I went to start the engine the battery was very low - almost dead - the engine turned slowly .... but it did start back up.
The next day when I went to start the tractor the battery was dead enough that it wouldn't turn the engine over - since I was in a hurry to get back to working with it, and due to where I had parked the tractor (couldn't get to it to jump it), I just went ahead replaced it with a Group 51R (original was a Group 55) from Autozone .... but I still have the old battery ..... and I'm not sure it's actually bad ..... (didn't check the voltage while running, although I will tomorrow - if I can get it started)
Next thing, when moving, there is some noise coming from the transmission - it is a whining or growling - something that it has always done to some extent, at various times under certain conditions and/or ground speeds/etc. ..... but it seems a good bit louder than what it normally was in the past .....
Finally, I had the small line (return ?) that goes from the fuel filter back to the fuel tank come off at the tank a few days ago .... admittedly I didn't pay as much attention to this as I should have when I first noticed a drip - I thought that perhaps I had accidently spilled some fuel when I refueled ......
Later, at some point (yesterday afternoon ?) my wife came over to where I was working, she pointed out that something was dripping off the bottom of the tractor .... dunno how long it was like that .... could have been for several days .... :mur:
I stopped the tractor and opened the hood and found the unhooked line and the right side of the engine covered in diesel. I reattached the small line back to the fuel tank and started it back up and continued to work for the rest of the evening and today.
One thing I was noticing this evening after the tractor died - there are two of these small fuel lines running back to the fuel tank - and the two lines pass thru an oblong hole in the rear firewall/heat shield.
What I noticed this evening was that both of these lines were so stretched and under tension that they were rubbing against the bottom of the hole in the heat shield/firewall ...
