welding station setup.
/ welding station setup. #1
Kendrick
Gold Member
Vermont
DK45S(Cab)
I am setting up my welding station for the farm. I must now decide how to best/most economicly get the pieces.
1) bernzomatic t grade heavy duty victor style kit 80$
1a) 140/200 for o/a tanks witl fill
1b) misc supplys 50$
2) lowes portable kit 280$
2a) misc supplys 50$
3) HF 130A ac/dc stick 80$
4) 3 in 1 longevity-inc either 160 or 200A tig/stick/plasma 600-1k
160 ac/dc =1k or 160 dc @600 800 for 200A dc
helmet 50-70$
I would prefer to buy once and never need again... but i dont have the money to just throw at it. Im really tempted to go with the 160A dc and then add in the portable oxy later when I get some more money in. its also tempting to go with the cheep portable (tanks included) and the HF ac or ac/dc stick for now sinced that would end up around 500$ now and I could possibly save up to get a 1.2k ac/dc 3 in 1 a year or 3 down he road. should I just go and buy the expensive 3in1 and or will the cheaper one end up costing more in the end?
Current projects
qa plate & hay attachment 15mm steel to be welded to make qa plate. (if i get the steel for it under 70$ can buy a qa for 120$) and angle iron for the rest of it.
truck bed flat. medium duty c channel or deck plate being the thickest.
body work on vehicles and straitening/cuting-welding toungue on hay wagon.
future project
build tracked gater for steep slope usage and mowing.
any suggestions on which way to go would be appriciated.
/ welding station setup. #2
I would get a med size plasma and spend the rest of your budget on a wire feed (mig) maybe a Hobart. I have been making stuff for 15 years and still don't have a torch. I will eventually get one but these tank leases are BS any more.
/ welding station setup. #3
Get yourself a good 220 volt Wire feeder like the Hobart brand as mentioned in a previous post. Either buy or rent a tank for the 75/25 Argon/CO2 mix. Dont mess with the elcheapo Harbor freight 110 volt stuff as you will just be replacing it. Also dont waster your money on any of the Harbor Freight welding wire as it is junk also.
As for cutting equipment, that is your choice and depends on if you are going to work on carbon steel all the time or need to cut stainless. A good oxy/acetylene touch is hard to beat when working carbon steel. Plasma torches are great but can be expensive for heavy duty rigs and the parts to keep the running are pretty costly. I like the oxy/acet rigs because you sometimes need to heat and beat and these rigs work best for that. I like the Victor rigs but other brands MIGHT work just as well. I never tried the off brand. The more versatile you get on your welding machines the more they are going to cost. You can get machines that will stick/TIG/ MIG -FCAW all in one, but if you are not a professional welder, the MIG wire feeder is likely your best choice. When properly set up, an untrained monkey could weld with them. It take a bit more skill and practice to work a stick or TIG welder and make pretty welds plus if you use a low hydrogen rod, you really need to keep them in a rod oven at 275 F that needs to be on all the time to keep them dry which is another expense. You can find cutting rigs used that are in good shape on craigslist or buy new for less than $300 (minus bottles) A good wire rig will run you at least $800 but then you will be ready to start building for about $1000 assuming that you already own some grinders, clamps other small tools Dont forget, a good vise is essential and an anvil is nice to have also. Again stay away from the cheap cast iron harbor freight vises as they are pretty weak. Look around and you can find some nice used vises of forged steel that will take a lot of abuse and not break.
/ welding station setup. #4
I guess I should mention that I do have a nice band saw for cutting. In my area getting gas bottles filled is a sad day, not to mention the lease every 5 years. They pretty much have you by the "short hairs" . That is why I avoid another two bottles (at least for now).
/ welding station setup. #5
It depends on what you are going to weld. If repair welding farm equipment I would go with a AC/DC stick welder with a name brand and a decent torch set like Victor or Harris. As said the torch is good for heating and beating type repairs.
If you are going to ge building stuff with new steel and not a lot of heavy duty welding I would go with the wire feed.
A stick welder is always ready to go if you keep our rods dry. A wire welder needs to have decent wrie and gas if you go the shield route.
Dan
/ welding station setup. #6
Dan
I agree. If budget is your priority $700 will get you into a good stick welder and torch setup. That's all I used for the first thirty years of my "home built" life. Hard to beat a Lincoln Welder and impossible to beat a Victor torch.
If you move into the Plasma/wire welder world you'll quadruple that budget to get the same quality. Then as said before you'll still want/need a torch because of it's versatility.
I've got a 180 Miller MIG/625 Miller Plasma/Heavy Duty Victor torch and own all my bottles with a total cost of somewhere around $3400 including supplies.
So you see there's no limit except your budget.
/ welding station setup. #7
Kendrick,
I see you are considering a Longevity in the mix. We can help you out in a similar manner with our 3 in 1. Or if you need a little better stick welder, our PowerARC 160 can be equipped with a Gas valve tig torch.
/ welding station setup. #8
Stay away from the HF welder. I bought one a long time ago (my first) and now regret that purchase. You'd probably be fine with a name brand 220v wire feed.
/ welding station setup. #9
Harbor frieght welder,,you serious?,,,I'd advise you to get a generator welder,,if you plan on welding sheet metal,get a constant current/constant voltage generator welder,,name brand,,make sure if you get a smaller gen welder,it welds in dc as opposed to ac[some smaller gen welders just put out ac]
I'd spend a little more money on the hood too[like 200 hundred or more].If you got torches,and your just working with steel,you really don't need a plasma torch now,you could get one later if you wanted.
I dont have the money to drop in to a gen/welder. we will be getting a gen head for the place. it has to be around 10kw for me to bother with it.
As for purpose. 50/50 between repair of vehicles/equip and fabing from new metal. new metal would be any thing from 20ga to 15mm. im planning on at least a couple things that I would probably make the whole thing including the qa adapter. when I went to the welding classes I ended up liking oa > stick > tig > mig. I doubt i will get a mig unless some one finds a reason to get me really excited about it. im the type for getrdun vs pretty. aslong as my welds are solid i could care less if they looked like a 3yr olds atempt.
Main reason for stick is hardfacing. afaik thats a stick only thing but not to important to me. quick stick welding bolts would be the other thing that comes to mind and who know what else i would end up using it for. stick would be most likely to be icing on the package but could be wrong.
now if i went with a 3n1 id be primarly using stick and might go to tig if i really had to or it ended up being that much easier. the clean cutting is the big draw for me there and the fact i can do 2 types of welding with 1 unit.
Torch I could do most any thing I needed would just have to decide between tote and 80's for tanks. now would it be easier or harder to weld a bolt with torch vs stick etc while its on a vehicle?
I have future thoughts with purchasing the tig. I may need to do ss welding in the future and doubt I will ever do alum but theres always a chance like if i got a wild hare... and put my truck flatbed together with alum instead of steel.
I have no issues using a saber/circ saw etc to chop up thin steel and torch the thick stuff. I may also be able to get lot of the thick stock bent/cut from the dealer so that may not matter. not needing power is also a bonus.
/ welding station setup. #12
helmet 50-70$
Current projects
future project
That HF welder is junk--I know from personal experience.
Get yourself a Hobart LX AC/DC stick welder and learn how to use it. 7000 series drag rods (7014, 7018, 7024) are the easiest ones to learn on. Once you get proficient on stick welding, the wire feed stuff will be easier to learn to do right.
/ welding station setup. #13
You can do two types of welding with any decent dc stick welder[tig and stick],any dc stick welder is a tig machine....
If you want a generator also thats 10,000 watts,,they have many generator welders that produce 10,000 watts,,for instance,miller makes one called a bobcat,book says 9,500 continuous,11,000 peak,its constant current/constant voltages[meaning you can mig/stick/tig with it],around 3,500 dollars,,time you buy your welder and generator,,you'll probably have more in them than that,, if you get a decent welder and generator.
Lincoln makes a simular one called a ranger 225,,costs even less than the miller.
/ welding station setup. #14
- Don't be afraid to buy an older used stick welder. I picked up a Hammett AC 200 amp for $25 at an auction. I have used it for years with no problems. While a DC welder is handy, with practice, you can weld in any position with an AC. I use mainly 6011 for 1/8" or thicker and 6013 for welding as thin as 18 ga. (I move the rod fast using a 100 amp setting.)
- While I agree the HF welders are only good for the home owner who only welds small occasional projects, I have had excellent service from their auto darkening solar powered cheap helmets. I see them on sale for $39.99 regularly and periodically for $35.95. I know several others welders who have purchased this model helmet who are very happy with it as well.
- If you start with the portable torch set which includes the tanks, you can always purchase larger tanks later and use the regulators from the portable set on them.
- As far a metal chop saws go, I have purchased 2 Dewalts, a Ryobi, and 2 HF saws over the years. The HF saws have held up the best! Believe it or not, the Dewalts have had the shortest life span. I have also had the same experience with the Dewalt 12" wood miter saws, three of them. The armatures keep failing before the brushes are even 1/2 worn. I have given up on Dewalt miter and chop saws. I can buy HF saws for the cost of replacing the armatures/shipping and they are only 1/3 to 1/4th the cost of a new Dewalt saw.
- For angle grinders, a Black and Decker 9" Wildcat would be my choice hands down! For the 4 1/2" grinders, I have B&D industrial, Dewalt, and $10 HF cheapies. The HF grinders sound like they may fall apart at any time but have lasted well. The B&D and Dewalt are basically the same grinders with different colors and work very well. I have been told the Dewalt has better bearings, but I can't tell a difference. (I have grinders with cup wire brushes, wire wheels, cut off blades, and grinding disks.) The wire brushes which are knotted (groups of bristles twisted together) definitely last longer!
The satisfaction of designing and building can be awesome! Have fun!:)
hehe I grabbed a 7" 12A HF magnesium angle grinder a while back and have not had any complaints. worst issue was having to put a 4" wheel on it to grind of a rusted bolt holding a strut on a car... impact wrench and heat didnt even touch it. even the air hammer didnt do much 10 min after i brought the angle grinder in 3/4 the nut was gone and the rest would freely turn.
Gauth I found an electronics safe 9k/10k generator head for under 1k after verifying the wave on it id much rather go with a seperate gen & welder. not to mention I cant afford 3k for both. its going to be hard to part with 1k for welding equip right now unfortunatly.
/ welding station setup. #16
Well,that money only goes so far I know.
I have a generator welder,its small enough that on its wheels,I can push it around,it puts out 6000 watts ac aux,all I need,,bigger ones need to be in back of a truck or trailer,but you got a gen/welder in one,not only that,with the models I listed,you got a mig machine,a stick machine,a tig machine and a flux core machine.
And don't think I'd want a three in one or 4 in one or whatever welder,,but like I said,any stick dc welder is a tig welder,,just need to hook stinger up to torch connection block,hook up argon hose to torch,run on dcen,,won't have high freg,,scratch start but welds are made every day and x-rayed with that set up.
Don't think I'd want a pto gen. either,where would I park tractor,,what if tractor breaks,etc.
But thats me,,just giving you my opinion,to each his own.
/ welding station setup. #17
Bernzomatic Heavy Duty?? is there such thing? Is it a good torch because it is $80.00 or because it is a Victor " Style " Does it have built in Flash Arrestors like Victor or is it just Gold in Color. This is the most dangerous piece of equipment in your shop and you are buying a " Look A Like " . Not in my shop.. Save until you can buy real equipment and you will never regret it. :thumbsup:
/ welding station setup. #19
Well,you would have to buy a wire feeder and flowmeter/bottle of gas of your chosing, for mig/fluxcore,,than for tig,you'd have to buy tig rig/reg/flow meters,argon tank and hose,,for stick you'd need to buy leads,stinger/ground,,,but no new machines,,,you'd have to buy most of that regardless of what you bought,,,cheap stuff or good stuff. Where did you get this new machines stuff???
Trying to save you a buck and get you set up,,please don't listen to me..
/ welding station setup. #20
Course I meant trying to help you spend your money:D
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
1997 International 3800 School Bus (A64194)
1997 International...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
