Mini Gooseneck trailer?
/ Mini Gooseneck trailer? #1
allthingsoutdoors
Kubota L3240
I am in the market for a gooseneck trailer and came across this for sale
Local Sales Network - all new gator mini gooseneck in somerset, KY #1731153 - Go LSN!
This is from Gatormade website. A MINI-GOOSENECK DESIGN WHICH ALLOWS THE TRAILER TO DISTRIBUTE WEIGHT DIFFERENTLY THAN A STANDARD BUMPER PULL TRAILER.
Is this marketing baloney or could there be any advantage over a regular bumper pull trailer?
I had always thought the advantage of the gooseneck was putting the tongue weight over the rear tires of the tow vehicle.
This mini gooseneck looks like it is putting the tongue weight in exactly the same place as a regular bumper pull trailer.
Anyone ever use one?
/ Mini Gooseneck trailer? #2
I think its made for flat bed trucks, not standard pickups. Its a specialty trailer.
But yes, you are right if it were hitched to the standard bumper hitch it would exert the same load as any similar sized bumper pull trailer.
Chris
/ Mini Gooseneck trailer? #3
Sorta agree with Chris on this. Looks like it'd go well on a 1 ton cab-chassis that often tow wedge trailers.
Kyle
/ Mini Gooseneck trailer? #4
I don't see any info on just what the advantage is. Looks like it would work with any bumper pull hitch setup regardless of bed style.
Makes for nice dual jack placement. At first I was thinking this would be a good place to set a front end loader bucket down on but then I noticed those grab bars or whatever they are. That and you would not be able to get at the tool box once the bucket was secured.
Need more info.
/ Mini Gooseneck trailer? #5
I really think its a GN trailer to only be used with a Cab and Chassis truck. Would work great with a flat bed truck.
I have seen a boat trailer made this way. The low slung tongue as compared to a normal GN trailer allows for the boat to be loaded very forward in that particular case.
Chris
/ Mini Gooseneck trailer? #6
/ Mini Gooseneck trailer? #7
I think it is to low for that. Also notice the ball coupler placement, it would rub the floor of the bed with a standard GN ball.
Chris
If the load is placed on the trailer the same but the tongue is streched out then the pin weight will be less. That is if the extra weight of the stretched tongue isn't to great.
/ Mini Gooseneck trailer? #8
I see what you guys are saying. I did not look at the coupler close enough. I can not see why someone would spend the extra money on it? Just get a regular bumper pull.
Chris
/ Mini Gooseneck trailer? #9
Looks like a waist of time and money to me.
Until someone can explain why?
/ Mini Gooseneck trailer? #10
It obviously has a purpose or they wouldn't have built it.
/ Mini Gooseneck trailer? #12
Imagine for a min your in the trailer makeing world. your trailers are built on jigs. which is to say a huge flat honkin chunk-o-steel aka I beams. there is a setup for every jig. it takes time... time = money.
so to save setup time, you build ONE frame on one jig setup. weather it be bumper pull or GN.
then you have some GN neck jig setup to weld those (the front part) so instead of having to change jigs and setups for when you change trailer types.
just build one. the only diffrence is the uprights are slightly smaller.
/ Mini Gooseneck trailer? #13
Chris
I did notice the coupler, but still on a cab and chassis often with a raised ball, it probably would not. Now, I saw it both ways and could believe it either way. Honestly, I'd get a regular gooseneck or a regular bumper pull and move on, IMHO.
Kyle
/ Mini Gooseneck trailer? #14
Bringing this thread back to the top; I stopped by Gatermade today to look at their dump trailers. More on that later since the topic is "minigoosenecks".
Seeing a car hauler and an equipment trailer with this setup, I just had to check them out. The salesman, while generally knowledgable on everything I asked, did not explain to me the advantage of the neck. Or, if he did, I did not understand him. We were standing by the dump trailers when I broached the subject too.
Kentucky does not tax gooseneck sales so I broached that aspect but indeed it is still a bumper pull so it is taxable.
He took off to leave me to mull things over so I drove over to the "mini's" for a once over.
I focused on the equipment trailer. It was about 20', low profile (wheels between the deck), flip up ramps and a slight dovetail. Warts aside, and as covered in various threads, this brand has some, I thought the trailer to be pretty nice overall.
The ramps had a built in stand to keep the front from lifting and the ground clearence to the tail was generous along with an angle of approach that was not bad. Stakepockets, at least ten "D" rings and a place for your forks if required took care of any equipment securement issues.
The "minigooseneck":
I think it would work with any bed style but would be better with a higher truck such as the Ford 4x4's. They had steps welded to both sides so along with the grab bars on top, it was easy to step up onto the deck. With dual jacks and the way they welded everything up, it looked to be able to take some abuse if need be. This one did not have a tool box but if it did, everything would be easy to access without bending over.
Mostly, I think the concept makes for a trailer that is easy to live with minimal bending over. This particular trailer was around 4200 and while I would certainly look at others, I would consider buying one if in the market. By the way, I have no ties to the brand.
Of course, there were scotchlocks and some of the paint prep could have been better.
Lastly, the main reason for my visit was to check out their 16', 14k gooseneck dump trailers but they only had some lighter BP's in stock.
I am downsizing to a 14k from my tandem dually Bri-Mar and have been mainly looking at the PJ's. Though Gatermade did not have the correct trailer for me to compare, the PJ is overall better albeit at quite a difference in price. Spec wise, the Gatormade comes with dual jacks and the three way gate is set up with chains for tailgating stone for example. The hoist however is only rated for 8k on a trailer that will legally carry roughly 10k.
In my lifetime, I have worn quite a few hats so to speak but my two main occupations have been driving and quality control believe it or not. If I worked for PJ, the production people would hate me because I would be doing my best to raise the bar. That is, to bring up some loose ends to support the reputation. Latches to hold the three way gate door open in swing door mode that did not line up and holes in the frame for the electrical that were blown through with a torch come to mind.
/ Mini Gooseneck trailer? #15
I didn't think of it till now but a lifted 2500 ram 4x4 just went by with a long drop shank to get to a trailer normal ball height (13-16") to keep the trailer level the mini goose neck would fit on a straight 2" 10,000 shank perfectly
tom
/ Mini Gooseneck trailer? #16
Its a good way to add some extra weight to your empty trailer for no reason... That won't pull as a gooseneck on any sized truck that would be needed to pull it.
I think its a sales gimick.
/ Mini Gooseneck trailer? #17
I agree with the reply of until "Gatormade Trailers" post an actual statement stating the advantage of the Mini-Gooseneck trailer... We only can ASSUME that it is a gimmick to sale trailers. Frankly there are some who will pay extra for a trailer just to be different. Anyways, is still an interesting looking, designed and advertised trailer. Just my opinion:)
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2015 NEW HOLLAND BOOMER 41 TRACTOR (A64280)
2015 NEW HOLLAND...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
