Electric hydraulic valve
/ Electric hydraulic valve #1
jinmared
Goldendale,Wa
Jinma 354 fwd
I am using a electric solenoid valve to control my root grapple, The valve works fine, my
question is : If I leave the valve activated in the closed position will this cause a deadhead
condition in my hydraulic pump? I am using my power beyond port off of the FEL hydraulic valve to supply this solenoid valve. I am using a DPDT on off on toggle switch for control.
/ Electric hydraulic valve #2
the entire pump flow will be by passed through the PRV at max pressure....100% of energy into HEAT!! HOT HOT HOT!!!
example....
10gpm at 2500psi= >> about a 14.6 hp(10.9kW) heater....enough for your winter house???
/ Electric hydraulic valve #3
jinmared,
If you were to use a momentary switch, the valve would not be energized all the time, but only when you press the up button or the down button. In the switch center position, no voltage to the valve.
/ Electric hydraulic valve #4
Yes.
Get a new switch! (ON)OFF(ON) where the ON in () means momentary activation.
Thank you all for the replies, I will get a new switch.
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
Wagon Wheel Chair (A64557)
Wagon Wheel Chair...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2017 Ford Expedition SUV (A64557)
2017 Ford...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2022 EZ-GO ELITE...
