princess auto hydraulics
/ princess auto hydraulics #1
jmbrozic
Cambridge Ontario
Hi guys
Has anyone tried the hydraulic cylinders at princess auto? I was wondering if they are any good? Also, why are the black ones so much cheaper than the red cylinders(besides the higher psi rating)
thanks james
/ princess auto hydraulics #2
You got it... the higher the pressure the cylinder is rated at normally the better it is and the more money they want, have run cylinders from PA ,tie rod type, screw cap ends (both black and reds) and have had good luck with them. You need to have the right cylinder for the job. It's a waste of money buying a 3000psi cylinder to open the tailgate on a pump body yet it's a problem buying a tierod cylinder to use as a lift cylinder on the pump body. Shop around though to see if the price at PA is a good one or not, i have bought identical cylinders at some hydraulic repair shops that were cheaper then at PA.
/ princess auto hydraulics #3
I'll second that, I can get valves cheaper (same valve) at Hydraulic Systems, and not $10 cheaper, either. More like 25% cheaper.
Sean
Thanks a ton guys
I am building a towable backhoe, metal work is almost done so I will need cyl soon. I'm in ontario so princess auto is close.....shipping is high to order. Do you guys know of any good places around kitchener,ontario?
Thanks again
/ princess auto hydraulics #5
With Princess Auto, you have to go in every week and collect your pieces for several months. That way you can get everything on sale. I scored a 6-spool BM40 for $199.99 I collected cylinders for my backhoe that were on sale and then built the backhoe to fit the cylinders. Sounds like you already have your metal work almost done. Good luck.
I'm ready for welding, but I have been holding off until I can get all my cylinders. It's hard to find good cheap cylinders and i'm not sure I trust the chinese ones....
/ princess auto hydraulics #8
Thanks a ton guys
Thanks again
what backhoe you going with? i like details!! i'd like to do one someday so im interested in all builds
/ princess auto hydraulics #9
I have had good luck with Princess Auto hydraulics, but better than that, I have had good luck with Princess Auto. I have probably purchased 20 thousand dollars worth of hydraulics, equipment, engines, trailer parts, tools and surplus junk from them and they have been very fair with the return of any sub-standard or problem purchases. I have found their hydraulic cylinders, spools, fittings and hoses to be trouble free in my experience. Any bad experiences have been with the odd electrical tool out of China, but they have been very reasonable with either refunds or exchange. I would recommend them.
/ princess auto hydraulics #10
My experience has been much the same. If I need top-quality tools, I usually buy somewhere else, but they're a good under-one-roof store for me to find most things I need around the farm.
Sean
Thanks again for all the responses. I think i will go with the red cylinders from PA. I am building a towable backhoe, but I think I will put 4 cylinders on the outriggers so I can stabilize on hills. I have not really got an official plan i will build with. I am just taking different ideas I like and will combine them. The motor will come from my 6.5 hp craftsman lawn mower,which I no longer use. The boom will be constructed out of 3/16 2 by 4 rectangular tubing (just to keep stress down at the joints). The bucket is approx 14" long 9" wide the boom will be about 6 ft and the dipper will probably be 5 ft, haven't roughed it out yet. The only thing I still really need is advise on which joystick is the best price/value......
Any suggestions
/ princess auto hydraulics #13
On my current project I was looking for some 1 inch bore hubs and PA was all out. I went to Canada Bearings, they sent me to their suppliers wharehouse, I searched and found the hub only to hear it would cost me $50. I said forget it and waited till PA had them back in stock. Cost $6.95. I would would not even be on this web site if PA had not been around to allow me inexpensive access to parts to build my projects.
/ princess auto hydraulics #14
do discount hydraulic etc. ship to canada?
On backhoe, don't forget to have enough weight/anchorage that the hoe doesn't move the chassis rather than the dirt, if you see what I'm saying.
/ princess auto hydraulics #15
I've bought a few of their red shur-lift cylinders for big farm equipment and they havent been very good and seem to eat a lot of seals . I do have a lot of hoses made there though and they seem ok !
/ princess auto hydraulics #16
With Princess Auto, you have to go in every week and collect your pieces for several months. That way you can get everything on sale..its so good
Well I cheaped out and bought 4 2" x 12" black princess auto cylinders. I do have a prince 3" x 16" for the main boom. Hopefully they will all be ok.
I could use some advice with best joystick if you guys have any ideas
Thanks James
/ princess auto hydraulics #18
I presently live in Hamilton but use to work and lived in Cambridge quite a few years ago,I don't think a hydraulic pump was mentioned nor a resivor to store the hydraulic fluid,could be a few more pieces needed as well,unless you already have bought these items,I shouldn't even be commenting here as I know very little about hydraulics,just what I've been told in the last two years from the young guys that work in the hydraulic section at Princes Auto,far as I'm concerned it don't really matter where you buy your hydraulic parts,it's an exspensive venture,but with what your building you need the hydraulics to make it work proper,post some pics if you can.....take care....Ampa.....:thumbsup:
The hydraulic pump is coupled to a 6.5hp gas motor, the pump is a gear pump good from 500 to 4000 rpm, hopefully it will be strong enough for this application. Pics coming soon. First have to weld everything this weekend.
Thanks James
/ princess auto hydraulics #20
I prefer princess auto to almost anywhere. No question refunds, I returned a steel cutter that was a year old , rusty, and had some holes drilled in it to hold the guard up. No questions! I have bought a lot from there but have probably returned 1/4 of it. When doing hydraulic work, I always buy some extra parts, if not needed I just return. I did buy a bunch from Hydraulic Supply for a large job,which was mostly cheaper but very hard to return by mail over a border.
1985 Kubota M4050 (A62180)
1985 Kubota M4050...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2017 INTERNATIONAL DURASTAR 4300 S/A 4X2 CAB AND CHASSIS (A59910)
2017 INTERNATIONAL...
Rears 500 Gallon PB5335TF (A62183)
Rears 500 Gallon...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
