Blown head gasket
/ Blown head gasket #1
Halmar
cub cadet 127
My brother brought over his Case 222 for me to fix. I knew immediately that it had a blown head gasket. Upon removing the had this is what I found. I have no idea how long he ran it with the blown gasket but it did do a nice jobonthe head. I noticed all the head studs were a little loose ikn the block but the nuts were tight. Would loose studs cause this much damage or is there something else I should look for? It is a 12HP Kohler.
Thanks,
Mark
/ Blown head gasket #2
These gas one lunger's are real easy to fix,but I'm not too sure about getting any info on this TBN forum on GT's....I use to belong to a LT GT(small tractor forum for all my needed advice, not saying for sure that someone on here can't help, Welcome to the TBN forum, Great/Helpful and interesting bunch of people on here,when I'm not asking questions, I'm reading all the interesting projects.....take care......Ampa
/ Blown head gasket #3
Thanks,
Mark
Looks to me that the gasket bos is eroded away. How is the head in that area? You may need to have the cylinder and head milled if there is enough meat on the bone. Maybe fill in the erosion by welding and than mill. This is not going to be a DIY job. Dont even think about DIY, you need a pro shop.
/ Blown head gasket #4
A few years back an acquaintance had the same thing happen to a single cylinder Kohler engine of his. As I recall, the problem in his case was traced down to a too lean fuel mixture, caused by extreme wear in the carburetor throttle shaft and bushing.
/ Blown head gasket
The block is O.K. It is cast iron. The head is aluminum and is shot. I replaced the head and got it running but it is missing and backfiring. I have to check the carb settings and the timing.
/ Blown head gasket
I replaced the head and have it running now, but it is missing and backfiring. I still need to check the carb and timing.
Thanks,
Mark
2021 John Deere Z930M Zero Turn (A63116)
2021 John Deere...
Starvox VOX-ASA Mini Auger (A62183)
Starvox VOX-ASA...
Arrow Quip 5500LV Cattle Chute (A64047)
Arrow Quip 5500LV...
2015 HAMM H11IX PADFOOT ROLLER (A64279)
2015 HAMM H11IX...
2021 CAM P4EC16  16ft 8000lb Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
