1500d starter
/ 1500d starter #1
BWSSR
Madisonville, Texas
Kubota L3200
I need a new starter! I think I have read somewere on here there is a Mitshubisi or other brand that I can use, rather than the $400 one....
Am I worng?
Thanks up front!
Bruce
/ 1500d starter #3
Unless the starter is burnt or broken they can be cleaned and rebuilt easily, I have had many apart for cleaning and most times that is all that is needed.
Craig Clayton
/ 1500d starter
Craig Clayton
Thanks!
I was thinking of buying new brushes and opening the thing up. I've done car and motorcycles, so......
/ 1500d starter #6
I had a starter go bad on my YM2620D. I found a small, excellent shop that was able to clean and rebuild it for under $100. The men suggested that a new solinod be put on. They had seen many starters in the past that were fuel soked and well worn. The rebuilt unit has worked great. Give your local guys a shot at it. They need the work. Dick
/ 1500d starter #7
You may find local shop better deal..replace,clean seal almost good as new.
/ 1500d starter
Pearland Alternator gets my call this week. Thanks folks!
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
429872 (A61166)
429872 (A61166)
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
